C4 Transmission Neutral safety switch
Roadrunner351w
Post by Roadrunner351w »
On the newer C4 transmissions the neutral safety switch is on the Transmission does anyone have the wiring diagram as to which wires go where. Currently I have no neutral safety switch at all so can anyone please help me on this.
Roadrunner351w
Re: C4 Transmission Neutral safety switch
if i was doing it i would run the wires up to the plug inside of the cab. to where the column nss would plug in and guess at the wire colors. they shouldnt vary a whole lot from the truck wires i wouldn't think but they could. oh maybe you can find the diagrams on here in the wiring diagram section or on www.fordification.net there are more wiring diagrams on that part of the site.
Roadrunner351w
Thanks. I figured it already the neutral wires are the same as the column wires even the same color and the other is the reverse lights. so now all I gotta do is wire it up. Thanks again.
Roadrunner351w
