Hi all! For those of you using the Crown Vic front crossmember, what engines are you running? Will it support the 390 or 460's? Also, what are the dimensions of the crossmember or what others will work, Mercury, Lincoln etc. ?
Scott
Crown Vic Front Suspension ?'s
'67 F100 4x2 SWB Custom Cab
'68 F100 4x2 SWB Ranger - 360FE
'84 F150 4x4 SWB XL - 300 Inline 6
'04 F350 4x4 CC DRW - 6.0 Powerstroke
'06 Expedition SVT - Blown 5.4 V8
Re: Crown Vic Front Suspension ?'s
2003 to present Panther suspension cars. Lincoln, Mercury, Ford. All will work.
I got mine from a police car
http://i165.photobucket.com/albums/u63/ ... ees068.jpg
and I'm putting this 331 in
http://i165.photobucket.com/albums/u63/ ... ees038.jpg
Because you have to fab up your own mounts,you can put any motor you like in your truck.
After the bugs are worked out with the small block we're going to a 521 or bigger
The Crown vic is exactly 36 inches from spring tower to spring tower, so if your vehicle frame was 35 1/2 you could sneak it in.
