WINDSHIELD information
Bobaloo2
Post by Bobaloo2 »
Are the 67 -72 windshields interchangeable with the 73-79? Seems like I read that somewhere...
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
OLEYELLERTRUCK
Post by OLEYELLERTRUCK »
They are the same from 67 through 79, mine has a 77 windshield in it as a matter of fact.
Bobaloo2
re: WINDSHIELD information
Post by Bobaloo2 »
Thanks, hows the weather further down south? Humid as heck here, causes rust in trucks...(gotta stay on subject).
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Drewskigrafix
Post by Drewskigrafix »
My '67 windshield is in excellent shape, however, there is rust under it's edges that I want to get. How is the best way to remove it without breaking? The last time my brother & I tried to get a windshield for my Festiva, we used a piano wire, & cracked it 1/2 way through.
Also, how do you get it started (the initial poking through)?
Thanks,
Drewski
Drewski
jzjames
Post by jzjames »
From the inside, take off the entire lip of the rubber gasket with a razor knife, etc. Take your time to get it all off. At that point there should be nothing holding the windshield in, except adhesion from the outside part of the rubber sticking from age, whatever. Try a putty knife to seperate the outside part if necessary. Take time, two people, try to get it loose before any heavy pushing. Piece of cake.
Drewskigrafix
JZJAMES,
Thanks for the reply. I'll try it the next time my brother & I are off on the same day.
Drewski
Drewski
I found when cutting the gaskets with a utility knife that I kept breaking the blades. I needed something a little more durable, so I grabbed my windshield trim removal tool, sharpened the back side of one of the tangs (yellow arrow) and then just run it all the way around the windshield in one motion. I've been using this for at least 15 years now. With this tool I can remove a windshield in about 5 minutes by myself. It works especially well when going around the corners, since you can easily steer it, unlike a utility knife.
You know what they say about necessity being the mother of invention. ;)
jzjames
Post by jzjames »
Good one, Kieth! Thanks!
jzjames
