Cam freezes up
wcm413
Cam freezes up
Post by wcm413 »
I tried a search but didn't have any luck . I'm putting a new cam and timing gear
in my 460 but when I tighten the timing gear the cam freezes up . Anybody know what
might be happening ? Can you use some sort of shim to fix the problem ? I appreciate any
help . I'm anxious to get it running , I've been getting all the parts together for 2 years .
Re: Cam freezes up
I know that some Fords have a spacer behind the timing gear but some aftermarket gears are designed to use the spacer and some have it built in. Also ensure you have the proper bolts in the cam retainer they could be hitting the gear if they are too tall.
knightfire83
Re: Cam freezes up
Post by knightfire83 »
Perhaps the camshaft retainer is not on correctly? Be sure the side with the small oil passage faces the block.
Other than that, maybe you have the incorrect camshaft timing gear?
1970 Ford F250 4x4 ~ Sold.
Re: Cam freezes up
yes it could be the cam timing gear and spacer that the factroy put behind the original gear.
