I like to change the original point & condencsor and coil ignition system in my 1972 F100 302, too the duraspark II system.
I have the BLUE strian module, large cap, rotor, cap adaptor, 8mm ign. wires, hi top coil, distributor & p/u module that came off of various later years of ford p/u's & vans having the 302 engine. The only part I do not have yet is the 1.05-1.15 ohm ballast resistor.
I have read in previous posts, that the original coil + source wire having the (pink resistor wire) which is inside the loom starting about 4" from the ignition switch RUN terminal MUST NOT BE USED.
Question:
Why can't the original wire with the built in resistor wire for the coil + side remain and be used, it already has a length of resistor wire built into it to feed the (Bat.+) side of the coil. Is it less or more then correct resistance value needed for the Duraspark II hi top coil .
I had attach a voltmeter to the coil + side and this is what readings showed. Everything still being original.
Key OFF = 0. volts
Key ON engine OFF= 6.34. volts
Engine running @ 700 RPM= 10 to 11.5 volts
Engine running @ 2500 RPM 14.2 volts
Question:
Are any of the voltags above too high which will eventually overheat and cook the Duraspark II modules or the hi top coil if I leave and use the original existing coil + side wire with the built in resistor wire.
Swap Duraspark II Using Existing Resistor Wire 72 F100
Re: Swap Duraspark II Using Existing Resistor Wire 72 F100
why not change to a TFI style coil and be done with it?? No resistor needed. The DII module will run on 12v just fine.
- craftsman
The coil needs the voltage reduced, but the module needs 12volts. If you go tfi coil you can run 12 volts to both coil and module.
- Redcap
Best option.craftsman wrote:The coil needs the voltage reduced, but the module needs 12volts. If you go tfi coil you can run 12 volts to both coil and module.
Or, do what I did...found a buddy with a MSD 6AL and a Blaster SS coil for CHEAP.
- sideoilerfe
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Or a HEI 4 pin module mounted out of site, high performance 12v coil and Duraspark II distributor. BUT to answer your question I thought when I was running one I used the stock resistor wire?
Here is one of the original conversion tech articles
http://www.carbdford.com/fletch/tech/du ... aspark.htm
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
What year harness did you pull? ballast resistance is 1.25-1.35 from 74-76, it decreased to 1.05-1.15 in 77.cheech63 wrote:I like to change the original point & condencsor and coil ignition system in my 1972 F100 302, too the duraspark II system.
Jim
'75 Ford Highboy 390 4spd
