351C/351M???
suavematt
351C/351M???
Post by suavematt »
Hey all
:hmm: Can I put my 351C's Crank & heads on a 351M Block????
I want the my 351C grunt, but I want to keep my BB bell-bolt pattern C6... Is it possible to make a 351C/351M hybrid???
Thanks! Later.
~ 8) Suave'
Name's Matt. I'm a southern' Boy with a love for the Lord & Carb'd Ford V8's hahaha... Anything else you wanna know... Ask ; )
1979 F-100 Super-Cab/Long-Bed Work-Truck [300 I6, C4, Ford 9" Rear]
1993 Ford Ranger, single-cab short-bed [2.3L 4-banger, 5spd trans, 7.5 rear... Full-time Convertable ; ) ]
1972 Ford Mustang [351-Cleve' (being built, still workin' on it), C4 auto, Ford 9" Rear]
Re: 351C/351M???
the heads are the same so that will work. i can only guess about the crank.
dbusedautoparts
Re: 351C/351M???
Post by dbusedautoparts »
You can not put a 351c crank into a m block and here is why , the 351c had a deck Hieght of 9.206 inches the 351m has a deck hieght of 10.297. the cleveland also has smaller main journals than the M motor 2.74 vs. 3.00 of The 351m. if you want to make a 351m perform the best thing you can do is change the cam shaft ford used a retarded timing cam in the 351-400 so by putting a nice towing cam with a good t-chain (not factory becuase it has the retard timing key) Edelbrock makes a good one or Summit racing brand, you will notice a huge increase in power. The 351M alos suffered from a lack of comprestion 8.3:1 from the factory this can besolved 2 ways plane you heads .010 and bore your block >030 over this with new TRW pistons will give you close to 9-1 Or pick up a set of Aussie Heads these will give you 10.1 comp. just buy bolting them on you can still run pump gas but will need to run 93 octane they where the only 2v heads that had a small chamber and will bolt up to you factory intake and exhuast of the 351M . these heads can be bought of e-bay for around $400.00 dollers they have a small 58cc combution chamber vs. the M Head's 79cc, You can use cleveland Heads but all of the us 2v heads for the c motor's had a 76.4 cc chamber so you wont gane much, The 4v US head had a 62 cc chambers so you will gane compresion but will need spacers for the intake and special headers to run them on your 351m Block Since they have huge 4V ports. Alot of people would through a 460 in but you will be ganing 175 lbs, and the 460 will not take the rpm like a well built 351m-400 motor . Hope this helps 8)
1971 F-250 4x4 ,390 4v, 4spd, Dana 44hd front , Dana 60 rear 4.56 posi, 9 foot fisher plow
1968 F-350 4x4 390 4v, 4spd, Dana 60 LP, Dana 70 4.56 LS , 8 foot plow
1995 F-350 4x4 crew cab 7.3L Power Stroke, 5speed, Dana 60,10.25 4.10 LS
2003 F-250 Supercab,4x4,V-10, Auto, Dana 60 front, 10.25 rear Locker, 4.10 gears
cdeal28078
Re: 351C/351M???
Post by cdeal28078 »
Pull out the 351M and drop a 460 in there. Gives you all kinds of room to grow. Keep it stock and have plenty of torque and get about 15 mpg or build it up and have all the torque and HP you could ask for.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
suavematt
Re: 351C/351M???
Post by suavematt »
Nice. Thanks a lot for the info' guys :thup: I really appreciate it. I guess I'll just keep the old Cleveland's block/crank together & throw em' back in storage then.... If the heads are the same & are a "bolt-on" mod, (even if only a slight increase) I guess I'll just give them a nice one over with a polish & all new valves, springs, rods & rockers & plan to use them on my 351M "Refresh" ....
:hmm: My 351C is indeed a 2V & came out of my old 72' Gran Torino Sport GT... I assume the piston chambers should be fine/the same measurement as the 79' 351M's pistons???
I'll also buy a new RV Cam & either a new double-roller timing-chain or set of timing gears.... & that should really Bring it to life eh' ? .... I'm also gonna be running the Black-Jack long-tube headers, & an the weiand "Action-Plus" aluminum intake + new carb' on it.... New rings on the pistons as well.
:fr: :2cents:
Later!
~ 8) Suave'
Brokenarrow
Re: 351C/351M???
Post by Brokenarrow »
I'm an FE guy, I never cared for the 351M/400 engines. Until I saw one that was built right. A 351M, or a 400 if built right, can be a "small-block with a big-block attitude". It'll wind like a small-block with the torque of a big-block. :2cents: ( But I'd still rather have a 390 8) )
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
dbusedautoparts
Re: 351C/351M???
I think youll be happy with a good towing cam and your cleveland haeds just remember to not over carb it a 650 edelbrock will be plenty for your set up.
dbusedautoparts
Re: 351C/351M???
http://www.projectbronco.com/Technical_ ... ild_up.htm Check this link out for a ton of good info on the 351m/400
suavematt
Re: 351C/351M???
Post by suavematt »
:thup: Thanks for all the info dbusedautoparts :fr:
I'm looking forwards to building up my 351M next year. I thing new timing gears, cam/rods/lifters & a "fresh" pair of polished Cleve' heads is gonna rock the ol' 79' Super-Cab/Long-beds world! :lol: :woohoo:
Later.
~ 8) Suave'
