points setting
sacramento_ford
points setting
Post by sacramento_ford »
do you know the gap for 390 points, im gonna do it right , the matchbook cover thing aint right, im gonna buy a gauge, thanks
heep70
Re: points setting
Post by heep70 »
It has been awhile but I think it is .017. :hmm:
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
stephen44
Re: points setting
Post by stephen44 »
:yt:
Point gap---.017
Plug gap----.034
Dwell Angle-26-31
Timing------10-12 BTDC
thanks
Stephen
sacramento_ford
Re: points setting
cool thanks . the matchbook thing is poor mans way, i got a feeler gauge thanks
70_F100
Re: points setting
Post by 70_F100 »
Feeler gauge probably won't get it much closer than a matchbook.
You need to get a dwell meter to set them right.
Re: points setting
i have a set of feeler gauges in my glvoe box. i also have a bok of mathces just incase i need to smoke? or the gauges have rusted up again and i need to buy another set.
sacramento_ford
Re: points setting
fordman wrote:i have a set of feeler gauges in my glvoe box. i also have a bok of mathces just incase i need to smoke? or the gauges have rusted up again and i need to buy another set.
distributor move a tiny bit,point open and close a little, this normal. enought to open and close it a little.
Re: points setting
when setting the points the dist shouldnt move. it could if you bump it some how. but if the center shaft moves some it could still be good enough to run. if it moves alot then the bushing are worn and need done something with.
