Water Outet Tree
JMcTurnan
Water Outet Tree
Post by JMcTurnan »
So I wan't to use my Marine Holley on my engine because it gives it some power. But it doesn't have any vacuum secondaries. Someone told me I could use a water outlet tree thats attachted to your water outlet. Is that true, where could I get it?
TNIceWolf
Re: Water Outet Tree
Post by TNIceWolf »
You gonna do what?
Presently in the stable
1969 Ford F-350 DRW
ToughOldFord
Post by ToughOldFord »
:yt: :eek:
Redcap
Post by Redcap »
do you mean a ported switch like this?
70_F100
Post by 70_F100 »
And that's supposed to do WHAT?????????? :lolprev: (not meant for your post, fordman)
JMcTurnan
Post by JMcTurnan »
Like it creates a suction like the carburetor vacuum ports were for the dizzy. Know what I mean?
70_F100
Post by 70_F100 »
Do you even know what vacuum secondaries are?
Do you know what MECHANICAL secondaries are?
ToughOldFord
Okay, let me try to decipher this. :doh: I think he's saying his marine carb doesn't have any vacuum ports for his vacuum advance.
Am I close?
70_F100
Post by 70_F100 »
Where is he going to pull his vacuum source from? :? :? :?
Redcap
Post by Redcap »
ToughOldFord
Must be some kind of hydro-to-vac Conversion Device. :D
vacuum secondaries arent to do with vacuum ports. that is all i know about that. the switch i posted is a ported vacuum switch meant to run with the dual vacuum advance distrbutors. with some other routings of vacuum hoses. i dotn have any pics. but if you look up a guy named 68-f250 or 68f250 (barry) and search his posts. he posted a vacuum diagram to use with this switch.
ToughOldFord
I know what you're saying Fordman, I'm just guessing that FM meant to say 'ports' instead of 'secondaries'. And apparently someone told him that valve you have there is another option for him. Obviously it's not, it's just a smog device that still relies on a vacuum port.
oh i see what your saying. yes then if he needed a ported vacuum soruce he could get one of these switches at the parts stores i think.
