300 HP from my '67 352 ?
stephen44
Post by stephen44 »
so i think by using search and google I have actually confused myself more now :(
as you all know - i have a '67 352 which 2 barrel which i assume is the 208HP version in my f100. I believe this is a stock 352 from 1967 - it even has the tag on the coil bolt ! I have the engine out of the truck now - so am going to de-gunk it - and will be able to get all the casting numbers this weekend.
I read that there were up to 300 HP 352's - from the galaxies(???) with 4 barrel set ups.....
so my question is if I put an edelbrock performer 4 barrel intake on my engine - with a good 4 barrel carb - and headers - will I get to the 300 HP figure or not ? - using the stock heads.
also can I just swap a cam while the engine is out to get a bit more (I want off the line acceleration) and if so what cam should I go for.
this is assuming that the rest of the engine checks out ok.
Thanks for all your patience whilst this Brit tries to get to grips with these engines :fr:
Stephen
thanks
Stephen
brents 67
Re: 300 HP from my '67 352 ?
Post by brents 67 »
I'm not sure about the 352, but the 390's had a high compresion motor in the car, and a low compresion motor for low end tourqe in the trucks. And unless I'm way off help me out guy's there was close to 100hp difference in thier ratings.
stephen44
Post by stephen44 »
yes - I've been reading some more :D - and I think I agree with you.
Perhaps some one could clarify.
is speed off the line due to torque or HP ?
thanks
Stephen
sideoilerfe
Post by sideoilerfe »
They had Police Intercepter 352s that made 350/HP or so. So I think it is possible. How much do you want to spend?
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
stephen44
Post by stephen44 »
well not too much $1000 or so - if i was going to spend much more - i might as well goto 390 + 0.050 etc etc...which at some point i might do - so i was thinking of getting parts that would wok on the 352 right now and then also work when I take it to 390-410.
so may be intake,carb,cam + headers - do you think that will get me close - I am starting to believe i have the low compression truck pistons in - so probably can't do too much !
thanks
Stephen
sideoilerfe
Don't waste your money on headers for your low compression truck FE. I had a 352 that ran great and I went to headers and noticed NOTHING. No performance or mileage gains whatsoever.
70_F100
Post by 70_F100 »
With manifolds, I like the steel gaskets.
They incorporate a heat shield in the design, which helps keep the heat from the manifolds deflected from the plug wires.
I personally would use them even if the manifolds and heads were brand new!!!
torquemonger
Post by torquemonger »
HP = speed tourqe is the twisting force put out. the harder it twists the faster it will go, but you need horsepower to keep that speed if that makes any sense.
67 mercury 100 352v8
2003 mustang gt 4.6L v8
grease,motors,and octane!!!
1967AceStroker
Post by 1967AceStroker »
I have the original 352 with no rebuild in my '67. I put some Flowtech long tube headers, edelbrock aluminum 390 performer intake, and a 600cfm holley carburetor on. It was a pretty good power gain, and a little better fuel mileage. And I imagine with headers, carb, intake, and cam you could make some decent numbers, and stay in your price range.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
SteveC
Post by SteveC »
my 352 with a cast iron 390 intake stock manifolds and such. I could feel a big difference just going from 2 to four barrel... In granny gear itll about lift the front of the truck off the ground if i get on the gas
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
stephen44
Post by stephen44 »
So I'm having real problems finding a 390 crank down here - none of the yards keep anything as old as my bump - and no FE engines ....
wonder what the shipping on one would be ?
- Stephen
thanks
Stephen
stephen44 wrote:So I'm having real problems finding a 390 crank down here - none of the yards keep anything as old as my bump - and no FE engines ....
Probably $40.00-$60.00 depending on how far.
If I had your goal (300 hp 352) with your budget. I would:
Put a set of car pistons in it
Put a stock Ford Car 4V manifold with a Holley on it.
Put headers on it.
Put a decent dual pattern cam in it.
That should pretty much do it for the money and the power and assuming the engine runs good now.
stephen44
Post by stephen44 »
Put headers on it.
so i have only 50 psi in one cylinder - goes back up with a bit of oil - rest are around 140 - so I think 0.030 over is probably in order !
Can you suggest a "Put a decent dual pattern cam in it." - looking for red light to red light performance only
thanks
Stephen
stephen44 wrote: so i have only 50 psi in one cylinder - goes back up with a bit of oil - rest are around 140 - so I think 0.030 over is probably in order !
Yeah, that is a problem, need to get it apart and have a look, you might get lucky and find a stuck ring or bad valve and not have to bore it. My advice on car pistons still stands, but you budget is going to get blown if it needs much (maybe any) machine work. My machine shop bill alone was several times your total budget, of coures I tend to get a little OCD about that kind of stuff.
stephen44 wrote:Can you suggest a "Put a decent dual pattern cam in it." - looking for red light to red light performance only
My suggestion would be a Crane 343941/343942, but since Crane does not appear to be rising from the ashes... going to take some research, Lunati or Crower probably...
stephen44
Post by stephen44 »
yup - this will be my winter job - now if I can just find a 390 crank :wink:
P.S. thanks for the advice - how does one tell if it just a sticky ring etc ?
- Stephen
thanks
Stephen
