radiator
kyle ray
radiator
Post by kyle ray »
How do i know which radiator i have? I am looking for a fan shroud and found that there are 3 different radiators for the 360. If yall have any ideas let me know. When i got the truck it did not have one so i cant look for a # Thanks.
Re: radiator
what is your truck. year size engine and transmission? its probably par tnumebr 43-2984 from lmc truck. the other one is for a 4wd or f350 they show 3 of them but 2 of them have the same part number. so it is only two choices.
kyle ray
Re: radiator
Post by kyle ray »
1968 360ci 3speed manual. 2wd
BobbyFord
Re: radiator
Post by BobbyFord »
Measure the core then look on Dennis Carpenter.com, shroud sizes and part numbers are listed.
kyle ray
Re: radiator
Post by kyle ray »
thanks for yalls response i will measure tomorrow.
Re: radiator
lmc truck part number 43-2834 stamped D3ta8146-A. pg 89 lower right corner of the page. dc doesnt show one in this book but this book is several years old. the one i have hear both of them anyway are C8TA 8146-S they are 28 1/4 wide total 20 inches tall. with a fan opening of 20 5/8. one of them i think came off of either a f250 or f350. the other may have came off of a dentside. i cant remember where i got it at now. the first one i bought from zakt.
Re: radiator
i just went to www.dennis-caprpenter.com. pg 27. D3TZ-8146-C also known as D3TA-DA the measuremaents are exactly what i have here. i didnt measure the hump in the center. i only measured the outer square. but it is thicker than the ones i have. it may work. i think mine are for without a/c i cant get to my other truck with a/c right now to check the part numbers or anything on that truck. i think its the same as i have here though. i then took mine out and set it on both fe radiators i have here. and lined up the botl hoel sand it fit perfectly on both of them.
