72 F100 won't start
3rdowner
72 F100 won't start
Post by 3rdowner »
Drove truck home! Started it a couple of times and let it set for 4 weeks. Wen't to start it and it wouldn't even try to start.
Changed plugs, condesor points, coil distributor cap and plug wires. Still won't even try to start. Plenty of gas and weak spark at plugs. Checked dwell everything ok. Tried to hot wire from batt. to coil woudn't start. replaced battery. repaired
breaks in harness from firewall to coil. Voltage still fluctuating at coil.
ED
70_F100
Re: 72 F100 won't start
Post by 70_F100 »
The voltage fluctuation at the coil is normal.
You should get a fluctuation each time the points open and close.
cep62
Post by cep62 »
I've seen badly flooded engines wash the oil off the cylinder walls.
Do a compression test if they're all low a shot of oil in the plug holes will bring them back.
While you're doing a compression test, you can check the timing with a light too
quote="3rdowner"]Voltage still fluctuating at coil[/quote]
The voltage will fluctuate at the coil when cranking because the points open and close.
How did it run before you parked it?
3rdowner
Post by 3rdowner »
The truck was running fine bfore we parked it. And I did flood it initially. Try to startagain in the morning. Ive had nothing but fords my whole life but have never been this stumped.
3rdowner
Post by 3rdowner »
Finally figured it out. My brother in law bought the truck and drove it home.
He then proceded to remove the plug wires. Apparently the previous owner set the dist. in one cog off and compensated by moving the plug wires around 1 position on the dist cap.
