Is this a Factory Fuel Tank Set Up?
cancow
Post by cancow »
Does this look proper? I am unable to get more than 10 gallons out of my in cab tank. Could the fuel line be too short going into the tank?
http://i30.tinypic.com/9ih6ab.jpg
flyboy2610
Re: Is this a Factory Fuel Tank Set Up?
Post by flyboy2610 »
Looks like what I have in mine.
that looks factory to me. so the tank when full when only let out about half of the tank and then run out? it could be the tank line has a hole in it and wont such up the fuel past the hole.
cancow
Post by cancow »
I fill up at the pump all the way up until is actually see fuel in the neck of the filler tube. Then I drive about 100 miles and run out of gas. I fill up again with about 10 gallons max.
fordman wrote:that looks factory to me. so the tank when full when only let out about half of the tank and then run out? or it just flows slowly?
it sounds like the suction tube has a hole in it. i read a story here that said the tube would come out of the tank. i dont think it will. but you could try to pull it out and fix it. or just get a different tank.
cancow
Post by cancow »
Why would it not come out of the tank? Is it bigger than the hole?
fordman wrote:it sounds like the suction tube has a hole in it. i read a story here that said the tube would come out of the tank. i dont think it will. but you could try to pull it out and fix it. or just get a different tank.
its like astraw. that has a hole in the middle of it. when the liquid gets down past the hole. it will only suck the air through the hole in the tube. because it doesnt have enough pull to pick up the fuel and force it to go up past the hole.
OldRedFord
Post by OldRedFord »
Why would the tube not come out of the tank?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
i have never looked at one or tried to take one out. i have no idea if they come out or not. does anyone know for sure?
BobbyFord
Post by BobbyFord »
Tube does not come out. Are you sure your cap is vented? A non-vented cap on a non-evap type tank will only allow the tank to suck half dry.
george worley
Post by george worley »
The tube in my tank got a hole in at about 1/2 tank. I took it out to clean it and seal it so while I had it out I drilled a hole near the factory tube and put in a piece of steel gasline. I left it about 3/4" from the bottom. I J-B welded the tube to the outside of the top of the tank and used a compression fiting with a screw in nipple and hooked the original gasline to it. It has worked fine now for a couple of years. I just don't let the tank get below 1/4 I really would like to get a new tank but money is tight.
cancow
Post by cancow »
Why does the "tube" not come out when there is a fitting on the tank? If what ever this tube is is the problem and it does not come out can i just drill it out and add a length of fuel line to the bottom of the tank?
BobbyFord wrote:Tube does not come out. Are you sure your cap is vented? A non-vented cap on a non-evap type tank will only allow the tank to suck half dry.
BobbyFord
Post by BobbyFord »
A clean, used, replacement tank at the boneyard is $20-$25, why mess with it if you're sure the tube is toast? I had a similar problem once and turned out to be a plugged charcoal canister (with a non-vented cap) on an evap-equipped tank. I wound up swapping the tank out with a non-evap tank, filler neck and vented cap and eliminated the charcoal canister.
cancow
Post by cancow »
Is there a way to tell if you have a evap-equipped tank? I have the press in key lock type gas caps. They seem to be original.
BobbyFord wrote:A clean, used, replacement tank at the boneyard is $20-$25, why mess with it if you're sure the tube is toast? I had a similar problem once and turned out to be a plugged charcoal canister (with a non-vented cap) on an evap-equipped tank. I wound up swapping the tank out with a non-evap tank, filler neck and vented cap and eliminated the charcoal canister.
BobbyFord
Post by BobbyFord »
cancow wrote:Is there a way to tell if you have a evap-equipped tank? I have the press in key lock type gas caps. They seem to be original.
No locking gas cap is original. Evap tank has vent tubes on the passenger side, top of the tank, running to a canister on the right frame rail near the core support.
About midway down you can see the emission fuel tank...
http://www.fordification.com/67-72ID.htm
