My 'looks new' 390
F100builder
My 'looks new' 390
Post by F100builder »
I've been kind of scarce on the site lately as I've been fairly busy. But I thought I'd post some progress pics of my latest work on my '69. I finally got around to swapping the old 2V intake and carb for the brand new aluminum Edelbrock and 600cfm carb I've had laying around. I also came across a set of old Cal Custom valve covers and dressed up the old FE a little! I like it!!! 8)
The before look:
Doctoring up the Cal Custom covers:
The underside of the stock manifold was actually pretty clean!!!
I only wished I had cleaned up the rest of the engine bay before this picture!
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
NM5K
Re: My 'looks new' 390
Post by NM5K »
Them valve covers look slick. The fun part will be trying to keep it all
clean.. :/
I had my engine and engine bay all painted up when I installed
my rebuilt long block back a few years ago.. Just to "stock"
look though.. IE: I used all the original parts and repainted
with the same stock blue, and black fender wells. Body color
firewall..
It's starting to look a bit grungy again due to a lack of
cleaning.. :/ And some parts of my repainted valve covers
have the paint starting to flake off a bit.
But I've been more worried about the body paint than the
engine. I really need to repaint my truck pretty bad.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
F100builder
Thanks! I actually powder coated the valve covers a single stage chrome color to make them look like polished aluminum (before the sprayed red between the fins). The nice part is that they just wipe clean and won't oxidize and turn a dull gray again! I also powder coated the hood hinges and inner fenders. It all is pretty easy to clean and very durable too!
Patrick
FORDTOUGHF100
Post by FORDTOUGHF100 »
F-N Ay Nice.
Skifu
Post by Skifu »
How do you get the paint between the fins without makeing a mess??
94 Ford F-150 super cab
300-6 eod auto,changing to NP-435
F100builder
Skifu wrote:How do you get the paint between the fins without makeing a mess??
Very tedious masking! I actually used an X-acto knife and a metal straight edge to cut the thin strips for masking the tops of the fins. I realize that thin-line masking tape is available but I didn't want to make another trip to the store or spend more $$$. This blue painter's tape is pretty good stuff.
Patrick
F100builder
FORDTOUGHF100 wrote:F-N Ay Nice.
Thanks!
Patrick
fomocoguy
Post by fomocoguy »
That looks great! How's she run? When I did this swap on my old 65 it REALLY woke it up.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
Skifu
Post by Skifu »
so,you spend really more time taping than anytihing else,looks nice,looks like you got a pretty cool shop.
Ranchero50
Post by Ranchero50 »
Skifu, You can also paint grease where ever you don't want the paint to stick...
Paint everything
Wipe off the 'grease' once it dries.
F100, nothing wrong with a hookers rebuild either. Red looks good.
Jamie
F100builder
Skifu wrote:so,you spend really more time taping than anytihing else,looks nice,looks like you got a pretty cool shop.
Pretty much. It's all in the prep work!
fomocoguy wrote:That looks great! How's she run? When I did this swap on my old 65 it REALLY woke it up.
It runs AND sounds killer!!! I've got full-length PITA headers and 40 series Flowmasters!
Ranchero50 wrote:F100, nothing wrong with a hookers rebuild either. Red looks good.
Jamie
:lol: Thanks Jamie! Not sure I've ever heard the phrase, 'hookers rebuild'! :lol:
This was all just to 'get by' for now. I've been taking it to local rod runs and cruisin' it around quite a bit and until now, I haven't wanted to lift the hood much! I've got another 390 sitting on a stand waiting a rebuild. Perhaps it will be this winter's project. :D
Patrick
sideoilerfe
Post by sideoilerfe »
You need to fix the links as they no longer work. I cannot see it. :(
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Ranchero50
Yeah, I didn't know if the censor would flag hooker's bath or not... Tape and paint rebuild, nothing wrong with that.
Jamie
F100builder
sideoilerfe wrote:You need to fix the links as they no longer work. I cannot see it. :(
Crap! I forgot and I moved some stuff around in my photobucket account. Should be good to go now! :oops:
Patrick
sideoilerfe
I see it now. Good job.
