68 f100 6 cylinder with carb problem
troy
Post by troy »
I just rebuilt my carb and now I do not have wet plugs.
Is there a step by step procedure to rebuild and rest a 1 barrel carb?
troy
Re: 68 f100 6 cylinder with carb problem
Post by troy »
If you have anything please let me know
70_F100
Post by 70_F100 »
troy wrote:I just rebuilt my carb and now I do not have wet plugs.
Not sure what you mean when you say "wet plugs"...
troy
Post by troy »
No fuel on the plugs.
NM5K
Post by NM5K »
Not sure the problem.. Usually, wet plugs is a sign of carb problems, not dry.
Dry is good unless you are pumping and pumping and never get any gas to run.
Need more data... If it's not starting, check for fuel at the carb, and if not,
keep going backwards to the fuel tank until you find the problem.
Could be clogged filter, lines, bad pump, etc.. If you are getting gas
to the carb, check for stuck needle/float assembly, parts installed wrong, etc..
With a normal running truck, the plugs if pulled should be dry, and have a
light tan color. Should not be wet, or have oil residue on them. Wet is a sign
of way too rich, leaking diaphrams, excess pumping to start, etc..
I'll assume you have a carter YF..
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
