Hey All,
I have a 67 F100 with a engine from a 65 Ford truck. It is a 240, straight 6, 3 speed manual, was originally a 3 on the tree but I converted it to a floor shifter. I was thinking of replacing the 1 barrel carb with a 2 barrel in hope of getting a little more power and reaction time out of the engine. Is it worth it? It isn't great on gas even with the 1 barrel. Just doesn't have any guts. It is very reliable and clean running motor. I rebuilt most of the engine when I switched it. Anybody have any experience with this? Is it even possible with out replacing the manifold also? Any advice appreciated.
Retriever47
Upgrading 1 barrel carb to 2 barrel worth it?
Re: Upgrading 1 barrel carb to 2 barrel worth it?
Thanks for the views, but I think I found my answer at "fordsix.com".
Any advice as to which carb to use would be helpful.
Thanks Again
Thanks Again
Still wouldn't mind some info from anyone who has upgraded to a two V carb. I'm leaning towards a Holley with an adapter and spacer to minimize the heat from then engine. Any problems hooking up the auto choke? Can I still rig it with a manual choke?
The 2v Holley 350 cfm an d the 2v 500 cfm come with manual chokes. The 500 cfm would be way to big for a 240 cid engine the 350 would be better. I think that the Autolite and Motorcraft carbs have the same bolt pattern as the Holley. If your adaptor is for a Holley these carbs should fit. They come in many different cfms and have automatic chokes as well as manual. ![2 cents :2cents:](./images/smilies/icon_2cents.gif)
Hey George,
Thanks for the info. I will look into the the Holley 350.
