351 Windsor swap question
What Sump to run?
Front
0
No votes
Rear
4
100%
Fox Body Swap
0
No votes
Total votes: 4
mrsnicks
Post by mrsnicks »
Hey Guys. If you have put a 351 windsor in your truck I have a question for you.
What type of sump are you running? Front, rear or the fox body swap pan? Any clearance issues with any of them?
Thanks,
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
craftsman
Re: 351 Windsor swap question
Post by craftsman »
I have one in a dentside with a rear sump, no clearance issues.
michael69
Post by michael69 »
I have rear sump with no issues in my 69.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
fitzwell
Post by fitzwell »
Rear sump in the 68..no worries.
tybob81
Post by tybob81 »
rear sump also
myboss
Post by myboss »
Running a front sump 351w pan in my 72 2wd. The only difference in a 351 and a 302 block is the 351 deck height is 1/2" taller than a 302. Other than that same / same.
dan
lololoeffler
Post by lololoeffler »
What about headers for this swap? Can you use headers for the 302?
1969 Ford F100
1995 Ford Ranger (daily driver)
2009 Kawasaki Vulcan 900 Custom
michael69
Post by michael69 »
Yes, I'm running 5.0 mustang shorty headers with no problem. I tried long tube but had clearance issuses with the front transmission cross member. Some guys here use long tube by notching the cross member.There are alot of treads on the site talking about headers and small blocks hear. Do a seach and you will find alot of info on your question. Hope this helps you. :thup:
Michael69
