tilt steering
- lobuck76
tilt steering
I finally finished the tilt column install. There are some pic's in the gallery
http://www.fordification.com/galleries/ ... ?album=237
'71 F-100
- hardtailjohn
- lobuck76
- 67RED
- GT-Racer
re: tilt steering
Looks great, whats the column out of?
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
- Joe Kriston
Lobuck,looks good...Would your original steering wheel work on that column,with the horn and turn signal guts and all?
This is the point...I'm....talking about everybody! I'm talking about form! I'm talking about content! I'm talking about interrelationships! I'm talking about God, the devil, hell, heaven!!!! Do you understand???? Finally!!!!
re: tilt steering
I KNEW I'd be able to use these pictures one of these days!
I was curious about this myself, since I really wanted to use an original wheel with my tilt column, so I tried this a little while ago. Unfortunately, the early wheel won't work. Not only is the tilt column's hub larger, the early wheel has protruding nubs that will hit the hub. You might be able to grind those nubs down to actually mount the wheel, but there's still the hub size difference, which would look pretty crappy IMO.
- boots
re: tilt steering
nice!!!!
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Joe Kriston
re: tilt steering
Didn't the '71 have that more modern two-spoke steering wheel with the vinyl skin over the horn?...One little annoying thing about the original turn signal switch is you have to completely 'click' it in position to change lanes,something you probably remedied with the new column...As far as steering wheels,anything looks better than those bright,metalflake 'custom' ones...
- heep70
re: tilt steering
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- lobuck76
re: tilt steering
Do they fit up ok on a truck column? Maybe PM me the details and we'll toss it around.
I thought about one of those and hooking up a horn button of some sort.I have a factory for sport steering wheel for sale. The one I have does not have any provisions for a horn, as it is from a pass.car, but all else is the same.
'71 F-100
