brake lines
re: brake lines
Hey, that's what the forums are for! ;)
Incidentally, the factory brake lines are 3/16".
Those Jeg's lines are stainless steel and pre-flared, which is good, since it's very hard for the average guy to do the good necessary double-flare on stainless lines. I'm not sure how long the line you broke is, but you'd have to get whichever is closest but still longer, and then make it fit by slightly bending it to take up the slack.
Their prices aren't bad either....but you can get regular steel lines from any parts supplier for a few bucks less and cut/bend/flare it yourself to exactly duplicate the factory bends. I did ALL the brake lines on my truck (with new fittings) for less than $30. And the 3/16 lines don't really require a bending tool unless you're doing very sharp bends, which a standard bending tool can't do anyway, so all you'd need is the double-flaring tool. I was actually very pleasantly surprised on just how easy it was to do.
In the long run, I think you'd be better off either finding a stainless set that is already specifically prebent for your truck or doing it yourself with readily-available steel lines.
:2cents:
boots
re: brake lines
Post by boots »
ahh ok, thanks alot!! well im going to inspect all the other lines tommorow, when i bought my truck the guy said he put new brake lines in, i just broke one becuase i was pushing the axel forward back into place as was not looking were i was pushing at so the line snapped were it had a bend :(
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
re: brake lines
You can get the rear axle tubes prebent from Inline Tube.
15.00 IIRC.
