Pertronix Igniter - worth it?
- 91Bear
It is worth upgrading from points to electronic ignition with these Pertronix kits? I've never messed with points and don't really want to tinker with them if the Pertronix is only about $70 and maintenance-free. Are they worth upgrading to?
- Alaskan Ford Driver
Re: Pertronix Igniter - worth it?
Points are really extremely easy to work on once you learn how. I have not installed the Petronix on any of my engines just because the points are easy to change and I have never had a problem with them. You just need a feeler gauge and about 5 minutes to adjust them. I have three engines that have points so for me it made more sense to just learn how to work on them. That is part of the appeal of older vehicles, you can actually work on them with basic tools.
Yes its worth it. Many threads on this. ![2 cents :2cents:](./images/smilies/icon_2cents.gif)
- drytoast
I did it and I noticed more horses and better fuel milage, not much but better.
Life is hard; its harder if your STUPID. John Wayne
1972 Ford F-100 Explorer 302 C4 automatic
2005 Chrysler T&C Limited
1996 Honda Accord LX 238,000 miles and counting
- tybob81
I think its worth it. Points are easy to change and adjust, but the flamethrower set up is nice smooth and reliable. I perfer the petronix II set up better because it is tuffer and won't burn out as easy. I would keep the points if you were going with the petronix 1 set up because they burn out easy if you leave your key on to long without the engine running.
- sideoilerfe
Just get a Durospark dizzy from a '75 and an MSD 6A box. Much better than the petronix.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- tybob81
Duraspark would be better but that involves hunting down the dizzy, wiring and box from a junkyard.
I second the Pertronix II
Yeah, the DSII is better also because if you burn up the module later on, every parts place that carries points also carries the modules.
But I run an Ignitor II with a Flamethrower coil. Why? Cause that way I get to keep my original appearing distributor setup. Only one new wire. Looks almost bone stock. Has been very reliable for 5 plus years.
But if orignal appearances are not important to you, then go with the DS II.
- sideoilerfe
Why don't you re-read my post. You don't have to hunt anything down in a junk yard. go to your local auto part store.tybob81 wrote:Duraspark would be better but that involves hunting down the dizzy, wiring and box from a junkyard.
- sideoilerfe
That is why i suggested the MSD 6A box.cdherman wrote:Yeah, the DSII is better also because if you burn up the module later on, every parts place that carries points also carries the modules.
The distributors are the same housing and use the same cap and rotor.cdherman wrote:But I run an Ignitor II with a Flamethrower coil. Why? Cause that way I get to keep my original appearing distributor setup. Only one new wire. Looks almost bone stock.
- 91Bear
I have no reason to leave the key on because my truck doesn't have a radio.tybob81 wrote:I would keep the points if you were going with the petronix 1 set up because they burn out easy if you leave your key on to long without the engine running.
Duraspark II Quick, easy, reliable. Parts available at the local parts store. Upgrade to a TFI coil & call it done. Have heard some rumblings about the reliability of the PertronixII units.
as always...![2 cents :2cents:](./images/smilies/icon_2cents.gif)
as always...
You can buy the Duro Spark dist. and module at Auto Zone, Advance and most parts houses. You get a rebuilt dist. and every thing is new. Easier to get parts for if you need to .
I'm a novice to all this do it yourself work on trucks. But I like to do it and learn in the process. How much work is it to put one of these units and coil on? Met a guy the other day who said you simlply pull out the old distributor and drop in the new one. Hhmm. Not so simple for a guy like me who has never "pulled out" a distributor. LOL Looks like a fair price for the Ignitor II and the 40k coil.
