engine priming
hotrod ford
engine priming
Post by hotrod ford »
what is the best wat to prime an engine that has sit for a while?
flyboy2610
Re: engine priming
Post by flyboy2610 »
A teaspoon of gas down the carb.
hotrod ford
Re: engine priming
what about for the oil system?
cep62
Re: engine priming
Post by cep62 »
Pull the plugs ,shoot some oil or atf in the cylinders then spin it over befor you put in the plugs .That should prime the cab and lube the motor, then try starting it.
BRUTUS_T_HOG
Re: engine priming
Post by BRUTUS_T_HOG »
well it depends how involved you want to be, you can take the distributor out and spin the oil pump with a drill, or you could unplug the coil wire and crank for about 10 seconds
ASE Certified Technician
VirginiaCityFord
Re: engine priming
Post by VirginiaCityFord »
I would pull the distributor and use a drill to spin the gear. then once you have it started run some ATF in it for a while then drop all the oil.
