Where on a 390 block engine is the number stamped that correctly ID's the engine by yr-correct size [ cu.in ] -production date and any other useful info?
Ken
390 ID numbers
- BobbyFord
Re: 390 ID numbers
There are no numbers on the block that identify cubic inch. There are engineering numbers and date-casted numbers.
Engine block casting number on the passenger side of the block near the 2nd cyl. and date cast number on the left front of the block near the oil filter adapter.
http://www.fordification.com/FEcasting-numbers.htm
Re: 390 ID numbers
Is there anyway to tell the differance between a 390 verse's a 360 by just looking at them? the reason I ask is that I bought a 76 F150 at an estate sell that had been sitting 8 yrs.. I was told that the truck had a 390...Fast forward 12 yrs ,tranny quits, I pull the engine and junk the body .I advertise the motor for sale as a 390. Four takers on day one of the ad but 2 say its a 360 1 says a 390 and one said it could be either one. I honestly don't know one from the other but could use some help
Ken
Ken
Re: 390 ID numbers
measure the stroke or pull the oil pan. there is a way to tell by looking at the crank. not sure how but i bet someone here does. since you have the motor out already it wont be hard to pull the pan
Re: 390 ID numbers
is there a sticker on the valve cover? try cleaning them with soem cleaner and see if you can find it.
- BobbyFord
Re: 390 ID numbers
360 has a 3.50" stroke and the 390 has a 3.78" stroke. Get the piston at tdc and with a wooden dowel inserted into the spark plug hole rotate the piston down in the bore, mark a spot on the dowel and measure the dowel.70shortwide wrote:measure the stroke or pull the oil pan. there is a way to tell by looking at the crank. not sure how but i bet someone here does. since you have the motor out already it wont be hard to pull the pan
- SteveC
Re: 390 ID numbers
i also remeber some thing about on the back of the crank shaft there were to different cuts into it.... one was a half moon and i cant reember the other or what each stood for
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- ToughOldFord
Re: 390 ID numbers
That is correct, the 390 has a full circle, the 360 is a crescent.SteveC wrote:i also remeber some thing about on the back of the crank shaft there were to different cuts into it.... one was a half moon and i cant reember the other or what each stood for
