It has been a loongggg five months..
I will need to seal the garage floor and we would like to find a sealant that can repeatably stand up to oil, gas etc??
Fortunately this was not a new build but a re-build after a major fire in January, so no worry's (at least it was not my mechanic skills that started the fireflyboy2610 wrote:Whatever you use, do not skimp on the prep job!
Also, double check with your contractor as to when the concrete can be sealed. I read somewhere that sealing concrete less than a year old isn't recommended, as it hasn't really cured properly before then.
