I have a 390 in a 69' F250 and 72' F350 2wd are those rear sump?
Todd
rear sump oil pan?
- zakt
rear sump oil pan?
1972 Ford F350 crewcab
![Image](http://www.fordification.com/galleries/albums/userpics/10045/350emblem~1.jpg)
Re: rear sump oil pan?
Not if the pans are the ones installed at the factory. All 2WD light-duty trucks had front-sump pans.
the rear sump pans have a large rear part of the pan. the front sump pans have a large front part of the pan. thats the fastest way to tell.
- robroy
Hi! Todd, I don't mean to change the direction of your thread, but I was wondering: do the rear sump pans fit a 2WD F250?
My new engine came with a rear sump pan (an 8 quart pan) and I'm not sure if it will fit or not. Based on eyeballing it it looks OK but I haven't tried it yet.
Thanks!
Thanks!
As long as you have the appropriate oil pump pickup and attaching hardware, they'll work just fine. Actually, switching to a rear-sump pan is a popular 'upgrade' to 2WD truck owners, since it greatly reduces the amount of cleanup required during an oil change, due to the drainplug on front-sump pans is located directly over the front crossmember.
