squeaky springs
squeaky springs
Hey guys ive got a 71 f-100 with a 6" lift coil spring front end. The coil springs rub on the upper and lower mounts and i was wondering if anyone knew of a way i could make the annoying creaks go away? The mounts and everything are tight, it just creaks enough to annoy me. Maybe like a plasti dip or teflon spray or something to put between the coil and mount? thanks
Re: squeaky springs
i have seen some plastic thin spacer things that go between the mount and coil. it almost looked like a thin piece of platic trash can that some one cut to put in there. that is how thin it was.
Re: squeaky springs
Never thought to do it to the bottoms but this is what I did...
http://www.panix.com/~alvinj/file12/coilspring.jpg
...and it held up real good for a couple years easy, then I
replaced that spring with another even heavier spring.
It was pretty heavy to start with, that's no wimp beside it... ;)
http://www.panix.com/~alvinj/file12/coilsprings.jpg
Anyway.
It's 3/4" fuel hose, a lot like what's on every fuel pump. :)
WD-40 (Stoddard's solvent and light machine oil) works about
as good as anything to slick it up. I remember it being quite
a good work out and wrestling match. :) That's with the coil
spring clamped in the vise (with aluminum pads over the jaws
so the spring wouldn't get scratched and later break there).
{edit}
Heck, just oil the suckers with STP if you don't want to take
your pickup apart. LOL :) No kidding on that, it'll work and
won't hurt nuthin'.
Greezy (or oily) leaf springs work too even...
http://www.panix.com/~alvinj/file12/zerks.jpg
http://www.panix.com/~alvinj/file12/zerks1.jpg
Alvin in AZ
ps- what's your "ride height" (as Ford calls it)?
http://www.panix.com/~alvinj/file12/rideheight.jpg
http://www.panix.com/~alvinj/file12/spacer1.jpg
http://www.panix.com/~alvinj/file12/spacer2.jpg
With 4+1/4" ride height...
http://www.panix.com/~alvinj/file12/F150front1.jpg
Anyway.
{edit}
won't hurt nuthin'.
Alvin in AZ
Re: squeaky springs
thats a good idea with the 3/4" hose. I think im gonna try that. thanks man i love this forum!
- bjde0b
Re: squeaky springs
I am in the process of painting my leaf springs and I spread a couple out and a bottle cap looking thing fell out. It was apparently in the divot in on the leaf. It was plyable, but very dirty so I didn't investigate further. Is this think maybe rubber and used to reduce squeeky breaks? It may be just enough to dampen the metal so it doesn't squeek. Is anybody familiar with these things?
Check out my build. http://s1088.photobucket.com/albums/i336/MyF100/
