p/s column mod
69rangerf100
p/s column mod
Post by 69rangerf100 »
ok i just got a p/s column out of a 73 f100. i have read the thread listed on the home page several time and can not seem to find the section that explains the mods that need to be done for 73 to 79 columms to make the work in in the 67 to 72 f100. can i get some help tracking this info done.
thanks,
David
:fr:
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
Re: p/s column mod
the only mods to that column i can think of is the wiring. some where in the electrical section a couple of guys have layed out the wiring swap colors for those columns to our trucks. what mods were you thinking of?
flyboy71
Re: p/s column mod
Post by flyboy71 »
Heres the two links on the gearboxes and shortening the column. :fr:
http://www.fordification.com/3spd-shorten.htm
http://www.fordification.com/powersteering.htm
-Jeff
69rangerf100
Re: p/s column mod
well for one thing that is confusing me a bit is there is the regular wiring harness then there is a another harness down torwards the bottom of the column that has a trailor wiring harness end on it and i have no idea why that is there i will post some pics of it in alittle bit to show what i am talking about.
David
Re: p/s column mod
that second harness goes to the neutrual saftey switch (NSS). for a manual transmission that will just have a looped plug on it. for an automatic trasnmission it will hook into you exsisting automatic transmission wiring harness. if your truck was factory manual you will have to wire the nss into you truck some how.
69rangerf100
Re: p/s column mod
ok thanks for explaining what that second harness is for. by any chance is there a thread that may have that topic b/c my truck was a manual and i have decided to switch it to a auto. when i bought the new cab for my truck it cab from a auto tranny truck and still had the entire cab harness in it would those hook up be on the cab harness
thanks,
David
David
69rangerf100
Re: p/s column mod
ok i just went down and pulled the auto cab harness out and found the spot in the harness where the nss plugs in.
David
Re: p/s column mod
ye si wasn't thinkign earlier. just plug the column into the place where it has the loop plug at. duh. its when you go from auto to manual that you have to make the new loop to bypass the nss on the column. you found it so you got it figured out it sounds like.
69rangerf100
Re: p/s column mod
yeah i did thanks for pointing me in the right direction Fordman, you always seem to have the answer that i need that helps me get things figured out
David
