early and late 460 differences
willowbilly3
Post by willowbilly3 »
I tend to forget some of this stuff. I know the blocks changed. And the efi intakes don't swap with the earlier 460s. What about the bell housing? Will the 460 ZF bolt to an early 429/460? What about flywheel? Heads? Could I put C8-D0 heads on a 96 460? thanks
BobbyFord
Re: early and late 460 differences
Post by BobbyFord »
Lots of info here...
http://460ford.com/forum/
texrodder
Post by texrodder »
willowbilly3 wrote:I tend to forget some of this stuff. I know the blocks changed. And the efi intakes don't swap with the earlier 460s. What about the bell housing? Will the 460 ZF bolt to an early 429/460? What about flywheel? Heads? Could I put C8-D0 heads on a 96 460? thanks
Block is same more or less,the bell housing pattern is same,heads/intake on EFI are different and wont mix/match with older heads/intakes.
averagef250
Post by averagef250 »
To bolt a 460 ZF to an early bottom end you need to either have a custom clutch made for an old flywheel or have a later flywheel internal balanced.
willowbilly3
So older heads bolt on the later engine?
What does a "custom" clutch consist of?
BobbyFord
Post by BobbyFord »
willowbilly3 wrote:So older heads bolt on the later engine?
It's easier and less expensive to have a later flywheel balanced.
