All that I half to do (as far as I know) is unbolt my front suspension (i-beams and all) and install the 76 front suspension take my steering column and steering box out notch my motor mount with a grinder so that the ford power steering box will fit, drill out the spot for the bolt hole in front of the old one, Then install the power steering column. and for the brake booster just unbolt my master cylinder and bolt up the brake booster/master cylinder and install the proportion valve(or whatever its called).
If you guys know any problems that I might run into please warn me in advanced so that I will be ready for it.
Thanks A lot guys. I will let all of you know how it goes.
