Fuel pump question
oddball
Fuel pump question
Post by oddball »
I have a 4160 that was spewing gas from the secondary vent tube. I rebuilt it, put new inlet valves and adjusted the floats and it still does it. The floats arent sticking but I didnt check to see if the floats had holes in them. They are the orange plastic Duracon floats and Ive never heard of these having problems. The only other thing I can think of is excessive fuel pressure. It has a fairly new stock style mechanical pump on. Is it possible for the stock pump to do this?
The Gardener from hell
67 F-100 4x4 4 barrel 352 4speed
65 Falcon Futura 302 4 speed
65 F-250 2wd 352 4speed... RIP
08 Toyota Tacoma 2.7 4x4 P.O.S daily driver business basher/camping rig
Re: Fuel pump question
i doubt it. i cant get those newer pumps to even work brand new. those pmps only pump abotu 12 pounds of pressure.
willowbilly3
Post by willowbilly3 »
How are you setting the float? I doubt if a stock fuel pump would be too much but you might try a pressure regulator set on about 3-3 1/2 psi
oddball
Post by oddball »
Good info guys thanks. I rebuilt the carb with a Holley kit. It came with new inlet valves which I screwed in dry. Ill check the O-rings to see if they are damaged. The floats arent nitrophyl, they are the orange plastic duracon ones. Im following Holleys dry setting for Duracon floats as far as the float setting goes. As I stated earlier the carb did this before and after the rebuild
willowbilly3
Did you check the float levels wet? You should have sight plugs that you can take out on the float bowls for that purpose.
oddball
Post by oddball »
The truck wont start and with the fountain of fuel coming out I dont think it would be a good idea.
binder56jd
Post by binder56jd »
i'm bettin with Keith
needle assembly--had a similar thing on an 1850
http://www.holley.com/TechService/Library.asp
now serving #235
george worley
Post by george worley »
I had same problem with my holley,tried several needle-seats all holley brand.Finally found some corrosion and old o-ring in the needle-seat opening in float bowel.Cleaned it and lubicated new needle-seat o-ring and adjusted the fuel level using the sight plug,fixed the problem.
