when you turn the key the starter cranks over and over and the engine would (sounds like) fire off one piston every other second. after checking under the hood and then cranking it again i didnt get that one pop every other second.
i checked out fuel delivery since that is always the problem, but the clear fuel filter is as filled as ive ever seen it. the engine could of gotten flooded but still doesnt explain this morning and after continuous cranking.
sooo its ignition right?
i dont know much about engines let alone ignition. but i know ignition has to do with electricity and electricity doesnt like water. and the engine is covered in mud water (from driving through big puddles on a trail, never had time to clean the engine compartment).
besides the mudwater covering the engine, i have also replaced the battery cables a couple days ago with fatter cables.
i was planning on starting the roll cage this weekend, no can-do if this thing doesnt get running
![Surprised :o](./images/smilies/icon_surprised.gif)
