front recovery point
- BRUTUS_T_HOG
what is the best place to attach a recovery strap when pulling or being pulled from the front?
ASE Certified Technician
- bumpside
Re: front recovery point
To the front
I couldn't pass this up ![Laughing :lol:](./images/smilies/icon_laughing01.gif)
1972 SWB Ranger XLT
`We'll hold the distinction of being the only Nation in the history of the world that ever went to the poor house in an automobile.' (Will Rogers)
- averagef250
Aound the engine crossmember if you have a stock front bumper. The axle works too, but you can mess up your tie rod. If you slam it real hard with a chain you can bend the front crossmember up on a highboy though.
- BRUTUS_T_HOG
i kind of wanted to avoid the cross member, and the axle is out of the question. just curious what people have been using
onmy 2wd i used to wrap the chain around the front frame rail behind the core supprt. but the chain would get stuck under the core support so i stopped doing that. since then i have avoided getting stuck. but i have use the engine crossmember. but not very much because of the front brake lines running behind it.
- averagef250
I've done some pretty serious tugging with the highboy engine crossmembers. They're about the only part beside the axle you can wrap a chain around and really slam hard without tweaking anything. You'll bend the front crossmember pretty easily if you hook there, hard to find one that isn't screwed up already though.
- mybros71
I usually go right to the frame. I use one strap to go around both frame rails, then to the center where I clevise the two ends to a second strap or come-along hook.
Tony
Tony
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
I like to weld a tow hook on the frame horn. You have to be careful about using a loop between the two framerails, it puts on a lot of squeeze, tends to pull the two rails together really hard.
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
55F100
- mybros71
I've never had a problem. I put it right behind the very front xmember.
x2 with the x-member in the very front. Got yank up over a rock ledge by 2 jeeps from that attchment point. (man I hated admitting that) ![Embarassed :oops:](./images/smilies/icon_redface.gif)
67 HiBoy - 390/435/TS'd205 HPD60f/FFD60r welded 3.54's 36x12.50x16 TSL radials
50 Willys P/U (project) - 302/435/205 FFD60r
the one time i got pulled out by the front i used a hook from my chain the kind with the two tabs with holes in them any way i put it on the rail where there was a hole and put the pin through it worked good untill i needed hook back but i never really get pulled from the front usually from the back bumper so i welded it on
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
- ok68crewcab
On a previous dentside I owned I bolted a tow hook to the underside of the frame rail. I have also seen people weld a large chain hook to the frame rail for an attachement point. Should be able to get one of the painted tow hooks for less than $20.
2 Blessed 2 Be Stressed
