fordman wrote:the way to tell which trans mount you need is to go to autozone . and look up the part numbers for the c6 and t18 mount and see if they are the same part number.
Hey that's a smart suggestion--thanks Fordman! Unfortunately, it both Rockauto.com and NAPA have different part numbers for C6 vs T18 mounts:
NAPA Automatic: Balkamp BK6201032
NAPA Manual: Balkamp BK6021237
Rockauto Automatic: Anchor 2329
Rockauto Manual: Anchor 2327
So John at Autofab.com already said he'd be happy to make a custom transmission mount if his existing C6 pattern wouldn't work for me.
fordman wrote:too expensive for me. he did say something about an adapter plate.
Yeah it's a little expensive, but he has the benefit of being the only FE upgrade mount place around (that I'm aware of). And yeah, the adapter plates should make the whole thing bolt-in.
DuckRyder wrote:I'd love to see some pictures if you get them. There must be some sort of adapter though...
Well now I
have to get them!
They sound like a fair price to me and I'd love to not have to worry at all about my motor mounts. I've heard plenty of stories about the stock FE mounts coming apart. And yeah there's an adapter for our frames, according to John at Autofab.com.
The only thing for me to work out with John at Autofab.com now is the transmission mount. I might need to ship him my existing mount for him to custom make one.
I also read in a mail from John that because his mounts use urethane bushings, it's normal to feel more engine vibration coming through the frame and body than you'd normally feel with stock mounts. At first this seemed like a disadvantage but after carefully using my imagination, it sounds like fun!
And here's my latest question:
How hard is it to change the transmission mount (given that the T18's installed in the truck with the bell housing on it, but the engine's removed at the moment)? I've never done this before.
Thanks very much for all the great advice!
-Robroy
