Thanks.
Are you on the right vacuum port. If the initial is 12 and the dizzy gives you 20 and the vacuum advance gives you 20 you would have 52 and that only works on blown engines. Vacuum Advance drops off with throttle opening like wide open no advance. If you are on the wrong vacuum port the advance will be on all the time.garycroix wrote:Attach vacuum advance, runs like crap.
