72 F250 Camper Special 4x2
- 72f250cs
Hello all,
I finally have my new truck home and I am starting to get around to fixin her up!! would like to post some pics for my profile but can't seem to find where our how to do it.....new to this forum stuff. any help is greatly appreciated.
FE 360, could have been an engine swap......old dirty sticker says 390 on aircleaner, however this is a "Y" vehicle for sure.
Anyway of telling the difference without opening the engine up?
Need some help or ideas on a carb problem...will usually start right up, idle rough at first. If to much gas is given it will bog out and die. Hard to get started again most of the time, will fire up on 1st try sometimes.
Looking for all the help I can get. Thanks
Re: 72 F250 Camper Special 4x2
www.photobucket.com is the best. You upload your pics to them and link them here. After you upload you will see an IMG Code clike on it and it will automatically copy it for you so you can paste it to the forum.
- 1970FordTK
Welcome from North Carolina.
Welcome form Southern Caifornia.
~'76SCS~ ~'76 F-350~ ~Anthony~ ©
'76 F-350 Super Camper Special ~Ranger-XLT Trim Package~
High Performance 390ci V8, 4-Speed Standard Transmission.
†GunRack †Premium Rust Package †No Mufflers †Ammo Box †No Smog Equipment
welcome! oh and as for the carb im assuming you are having this problem despite a choke? or are you not choking it?
- FormerMarine1981
Congrats on getting it home, Welcome to the site
welcome from tennessee
- flyboy2610
Welcome aboard!
- RedneckTexan
Howdy from TEXAS!
- 72f250cs
I don't have the choke knob inside the cab. I have adjusted the choke, backed it off a bit from being "fully lean". It seems to run a little better, however still having the same problem. I also noticed that the tube running from the exhaust mainfold is running into the back of the carb. Shouldn't this go into choke? If I can ever figure out how to post pic's I can through on up and ask for help.mbuchman wrote:welcome! oh and as for the carb im assuming you are having this problem despite a choke? or are you not choking it?
- 72f250cs
thanks....I see you are from NE, I was born there and have some family in Plattsmouth and Omaha. Was back there about 2 years ago, really miss the old flat land.flyboy2610 wrote:Welcome aboard!
72f250cs wrote:I don't have the choke knob inside the cab. I have adjusted the choke, backed it off a bit from being "fully lean". It seems to run a little better, however still having the same problem. I also noticed that the tube running from the exhaust mainfold is running into the back of the carb. Shouldn't this go into choke? If I can ever figure out how to post pic's I can through on up and ask for help.mbuchman wrote:welcome! oh and as for the carb im assuming you are having this problem despite a choke? or are you not choking it?
ok im confused if you mean the vacuum tube of the manifold is running into the carb that does not seem right. maybe those smarter than me will correct me but that sounds like vacuum is hooked to vacuum rather than running to anything that it needs to. also do you have an electric choke? or do you just have it rigged to be permanently choked? as for posting pics just open a flickr account or photobucket and just read any of the sticky posts on how to post them to the forum. and if you have a manual choke i would go buy a choke cable kit for like $5-10 and run it to the cab. It sounds to me your problem could be as simple as that.
cheers
Mike
- SteveC
welcome from North Platte Nebraska.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- ford4x4fun
from TN, I will let those smarter than I help you with the carb issue!!!
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
US ARMY Retired
