flex o matic rear
Pipes71
flex o matic rear
Post by Pipes71 »
hey I was wondering if we had any info on the flexomatic rear set up on some of these trucks.. I know it was optional..least I think so, and I was just curious about the pros and cons of it.
Tony
bumpless but still diggin them....
rubiranch
Re: flex o matic rear
Post by rubiranch »
Seems like at one time I asked the same question and was told all F-250s came with the flex-o-matic rear springs.
72 F-250 CS XLT 390 C-6 4.10 40k miles
You don't shoot to kill, you shoot to stay alive.
I don't carry because I have to, I carry because I get to.
http://www.fordification.com/galleries/ ... ?album=514
ezernut9mm
Post by ezernut9mm »
they are supposed to give a smoother ride unloaded while being able to handle the heavier loads of a stiffer spring. the only downside i saw was that you can't use drip shackles on rear to lower your truck. other than that, i don't the=ink there is a down side.
Pipes71
Post by Pipes71 »
thanks guys! thought there was something on the site about it but couldnt find it.. figured someone on the forum would know!
Tony
ezernut9mm
wow, it must have been drunker out than i thought last night. :D glad you made sense out of that post.
Pipes71
Post by Pipes71 »
ha..I read drunkenese
Tony
NM5K
Post by NM5K »
Little bit of factory propaganda..
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
SteveC
Post by SteveC »
they must have started the flex-o-matic rear end around 68-69 cause my 67 f250 doesnt have them. My 70 f100 with only a 4500 gvw has the flex-o-matic though
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
ezernut9mm
my 67 f100 has it.
SteveC
Post by SteveC »
hmm weird my f250 doesnt at least nothing that looks like that pictured... my 70s looks like it though
1967 f-100 4x4
BMJs 67
Post by BMJs 67 »
My 67 has it.
Daily driver:
67 2WD, 390ci
tybob81
Post by tybob81 »
The 67 f100 4x4 we are restoring for a customer doesnt have them but my 68 f100 2wd, my 67 & 69 f100 2wd parts trucks have it to.
