What motor do I have?
I pulled a motor out of a 74ish pickup that a guy rolled not bad it had an eldebrock carb and hi rise manifold and headers and got it for a floor job. My question is on the side of the block by the headers it says C8AE-H which means it's a 427 with a hydraulic lifters and side oilers is this right??? Please help i'm lost i didn't think the come out in that year of trucks?
The dumbest question in the world is the one you don't ask.
- SteveC
re: What motor do I have?
try this out http://www.fordification.com/FEcasting-numbers.htm
there is a possibilty that isnt what it is but some one that has seen one in person may be able to tell you better than me
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- Hawkrod
Re: What motor do I have?
C8AE-H pretty much guarantees that it is not a 427 side oiler. The C8AE-H head was only used on 360 and 390 engines from the factory in a pickup (and low performance 428's in cars). The odds are it is a 360 as that is teh most common of the two in thses old trucks. Hawkrodwolfpack wrote:I pulled a motor out of a 74ish pickup that a guy rolled not bad it had an eldebrock carb and hi rise manifold and headers and got it for a floor job. My question is on the side of the block by the headers it says C8AE-H which means it's a 427 with a hydraulic lifters and side oilers is this right??? Please help i'm lost i didn't think the come out in that year of trucks?
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- Wes
Since the motor is out pop the pan and check the crank numbers that will remove all doubt
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them![Smile :)](./images/smilies/icon_smile.gif)
67 F250 High boy
69 Bronco
cool guys thanks, i was thinking it might be a 360 or 390 and thats cool, because i thought thats common in those year of trucks....
- Hawkrod
Amazingly enough, not all 427's have cross bolts. The marine/industrial engines were sometimes made without them (and there are no records as to why that have been found yet) so never discount missing crossbolts as being a standard engine instead of a 427. You won't find many but occasionally one pops up on eBay and everybody poo-poo's it and it could be a great buy. They are designed to handle crossbolts so they can be added with new caps. Also note that there are 390's and 428's with the provisions for crossbolts but that is not what I am referng to. HawkrodBobbyFord wrote:A 427 will have cross-bolts for the mains on the side of the block, near the pan.
The infamous 427 without crossbolts:
http://www.network54.com/Forum/74182/th ... n+other+FE
http://www.network54.com/Forum/74182/th ... o+bolt+427
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
