Any recommendations for tach' and vacuum gauges?
robroy
Post by robroy »
Good morning!
I'm interested in picking out tach' and vacuum gauges for my truck.
I'm thinking about gauges three inches in diameter to mount in a cluster somewhere inconspicuous yet easy to view without taking my eyes far off the road. Suggestions on the mount location based on experience would be very interesting to me!
I'm also looking for the best quality gauges I can buy, preferably made in the USA. A more conservative and classic appearance is preferable to a modern, flashy appearance.
Does anybody know of a great source for gauges that match my specs?
Thanks very much!
-Robroy
td
re: Any recommendations for tach' and vacuum gauges?
Post by td »
these guys make what your describing check'em out and see what you think. http://www.dolphingauges.com/ you could always buy some mounting cups and mount'em under the dash. i have some in this location myself right now but i in the process of moving them all to the dash bezel.(edit) sorry that link didn't work,will somebody clue me in on how to make it work. (another edit) i figured it out thanks anyway.
td
Post by td »
i know these aren't the style you after but it will give you an idea what they would look like placed here.also mine are 2 5/8 im sure you would want to go with somthing a little smaller.Image
robroy
Post by robroy »
Good morning Td!
Thanks very much for the excellent link! I checked it out and believe they do have what I'm looking for. I just wish the photos on their web site were twenty times as large and detailed--it's pretty hard to see the nitty gritty there. I think I'll mail them to see if they have better photos somewhere.
Thanks also for posting the photo of your interior; I might wind up mounting mine there!
-Robroy
td
Post by td »
they do have a cool product, deffrent color faces,and trim rings. i haven't used any myself but have seen them in person, they have great classic looks. and you can get the speedo in manual or electric versions.
robroy
Post by robroy »
Hi Td! Thanks for the info. A chap there responded to my mail already and said that they don't have any vacuum gauges.
Do you happen to know of anything similar for a vacuum gauge?
Thanks again,
-Robroy
td
Post by td »
im sorry i over looked the vacuum gauge part of your initial post, my bad. no i don't have any knowledge of vacuum gauge manufacturers. good luck finding them thou. have you tried googling (vacuum gauges) and see what comes up?
robroy
Post by robroy »
Good evening Td! Hey no problem; I'm grateful for the excellent lead for the tach'.
I haven't searched the web for it quite yet. Sometimes I like to ask before searching when I figured another Ford guy might have just what I'm looking for on their truck.
Thanks for your help Td!
-Robroy
td
Post by td »
no problem! :thup:
You may find what you want at:
http://www.stewartwarner.com/Products/prod1.html
http://www.vdo.com/products_solutions/s ... mentation/
http://www.autometer.com/cat_gaugeop.aspx?sid=52
Although the USA built part is likely to be difficult...
There is a thread from a while back with some Tach mounting solutions...
http://www.fordification.com/forum/viewtopic.php?t=5162
but I think we lost some of the attachments...
robroy
Re: Any recommendations for tach' and vacuum gauges?
Post by robroy »
Thank you for the links Robert!
I heard from my engine builder (Proformanceunlimited) today that I should be looking for mechanical, oil filled gauges. Steve recommended the Autometer models. So my search is on again now that the engine will arrive on Friday!
I'll be sure to post pics of whatever I pick up and install.
Thanks again Robert!
-Robroy
mljjones67
Post by mljjones67 »
I like the auto meter gauges. They look good and built well.
robroy
Post by robroy »
After looking around at the manufacturer web sites, I'm failing to understand why mechanical gauges are more desirable than electric ones. It seems a little wild to have actual engine oil coming up in to a little box a foot away from my face!
Why do folks prefer mechanical gauges for performance applications?
Thanks!
-Robroy
mljjones67
I think they are more accurate. It acually reads the presure of the oil pumping through the gauge. That would be my guess anyway. I dont see why an electric one wont be sufficient .
theskytoucher
Post by theskytoucher »
The main reason is mechanical gauges react faster to changes!! Electric gauges have a lag in them which can be the death of a motor!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
