grrr what a pain
67 ford f100s rule
grrr what a pain
Post by 67 ford f100s rule »
I was mocking up one of my inner fenders. i went to un bolt it from the cowl and one of the square nuts on the other side of the cowl wall started spinning. now i cant get it off. :cry: i unbolted the inner from it so it wouldn't cause anymore trouble when i try to get it off. how can i get to that nut???
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
1971ford
Post by 1971ford »
oh man that happens alot to me. stupid old U nut things. they always break :cuss:
i usually resort to a sawzall (how do you spell that :? ) or if possible i grab the nut with pliers or you can try to jamb then nut on something or pull on the bolt while you ratchet on it to try to keep the nut from moving
-Ryan
re: grrr what a pain
You'll have to remove the inner fresh-air vent on the side kickpanel and reach up. Just remove the cage (use some ViceGrips) and use a regular nut/bolt.
foghorn
Post by foghorn »
If it was one that was spot welded on try to drill a hole on both sides of it then spot it back on with a mig.
Foggy 8)
