topcoating por-15
1971ford
topcoating por-15
Post by 1971ford »
ive read the directions over and over and they keep mentioning that i should read the directions on how to top coat por-15. i was reading the directions, i dont get it.
the por-15 is completely dry now, i can still rattlecan over it right? i remember something about topcoating while it is tacky. :dk:
-Ryan
Re: topcoating por-15
1971ford wrote:the por-15 is completely dry now, i can still rattlecan over it right? i remember something about topcoating while it is tacky. :dk:
NO, you cannot still rattle can over it, at least not without using tie coat primer.
It is too hard and smooth for a topcoat to "bite". If you are planning to top coat you have to mist it before it dries as a tie coat.
rjewkes
Post by rjewkes »
but would more por stick to the allready drie stuff?
fuelly.com
1971ford
Post by 1971ford »
ahhhh crud. so i cant rattlecan over it :hw:
whats tie coat?
-Ryan
rjewkes
Post by rjewkes »
i think its what he was talking about with the rattle can while tacky.
but theremight be a primer called tie?
wonder if a self etching would stick to the por? or would it just compromise it?
fuelly.com
1971ford wrote:what is tie coat?
http://www.por15.com/prodinfo.asp?grp=TC&dept=3
1971ford
Post by 1971ford »
damn there goes more project money funds for my stupid mistake :doh:
another question.
i noticed today that i must of missed a spot when applying the second coat on my core support, it is a very light coat showing the metal underneath. can i apply another coat over the dried por-15?
so putting por-15 over dried por-15, is that ok?
-Ryan
1971ford
Post by 1971ford »
bump
and also i just noticed a run on my inner fenders right where its noticeable the most, how do i get rid of a run :eek:
-Ryan
seattle67
re: topcoating por-15
Post by seattle67 »
Ryan,
A long time ago I painted the frame of one of my street rods with por-15 and after it dried I noticed some runs. I don't know if the manufacturer would recommend this, but I just wet sanded down the runs, roughed up the surrounding area a little and recoated with por-15. It seemed to work just fine.
Dan
1971ford
Post by 1971ford »
oo cool thanks. ill try to razorblade it off too and sand.
-Ryan
Texas69
Post by Texas69 »
Doesn't por15 look good without paint. I too want to paint the inner wheel wells on my 69. I was just going to paint por 15 on frame and shock, spring mount since I am replacing the old suspension from drum to disk.
1969 F100 Ranger shortbed 360 3 on tree.
1971ford
Post by 1971ford »
it looks great without a topcoat, but por-15 is UV sensitive (doesnt like sunlight) so if it is left in sunlight it will discolor. so you have to topcoat if it will be in sun.
-Ryan
72stepside
Post by 72stepside »
Yeah, it loses its shine and gets kinda chalky.
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
jim bruce
Post by jim bruce »
Well, you have had a fair response on this item so perhaps you do not need more information. I have used POR products extensively on a ground up restoration on a 67 F250. I tried to use 3 coats of POR 15 on most areas. POR recommends the 2nd coat be applied as soon as the first coat dries to the touch. I have actually painted on the 2nd coat the next morning and it seems to work fine although that was this winter when it was colder. Also if you are using POR frame paint (I used their semi-gloss black on the frame and under fenders and bed) they recommend it be put on as soon as POR 15 is dry to the touch. If you wait for a couple of days before top coating they recommend first to either light sanding or paint with their self-etching primer or the other product that someone else mentioned in an earlier form resonse.
