lmc door patch panels
345window
Post by 345window »
well I learned the hard way not to use lmc lower door patch panels, at least the ones I got were flat below and above the lower body line after welding the 1st one in It was horrible I had a bad feeling from the start but ignored it, to fix I had to make a template from my other door and used my stud gun all the way across the door to pull it as close as possible to the right shape and used the duraglass cure all to get a true shape. at least I had the lower door piece I cut out to repair the other door maybe I am the only one w/this experience if not lets here about it if this pic thing works heres the 70 so far
71Ford100
re: lmc door patch panels
Post by 71Ford100 »
Most of LMC's stuff is junk. DC's patch panels for the most part are better but idk about their door skins.
Lance Peters
QC
Post by QC »
345window, what part of Washington are you in?
69 F-100 Ranger 302
345window
Post by 345window »
Hi QC Im about 5 miles west of chehalis
1971ford
Post by 1971ford »
LMC = POOPY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-Ryan
