How should the hood sit?
Chaseman
Post by Chaseman »
The guy before had the hood sitting funky so I'm going to adjust and or remove these rubber things I know aren't ford.
Any advice or how it should sit?
Thank You
Wes
Post by Wes »
Part of the rubber bumper is is ford looks like it has been shimmed. the hinges and or the inner fenders need to raised up. I would line the hood up with the cowl 1st then maybe the fenders to straighten out the gaps.
Wes
67 F250 High boy
69 Bronco
AlleyCat
re: How should the hood sit?
Post by AlleyCat »
Chaseman, the hinges are adjustable where they bolt to the inner fenders.It looks like they need to come upward a bit.Loosen the rear hinge bolts first, the middle bolts, then the forward bolts.As you loosen the forward bolts the weight of the hood will start to pull the rear of the hinges upward.Snug the bolts and see check the alignment.Once it's level the gap to the cowl will likely be too big.The hood can be moved reward by loosening the bolts that hold the hood to the hinges.The hood can be slid forward or backward.
When you check fit don't slam the hood just close it slow.If it binds stop to see why.It is possible to bend something if you make a mistake. :(
BTW, the rubber blocks are from Ford.I've never seen a bump that didn't have them. :)
Clay
rjewkes
Post by rjewkes »
hope nothings rusted alowing the sag.
also if a 70-72 i think they also had a rear peice of rubber.
fuelly.com
FLATBEDFORD
Post by FLATBEDFORD »
I spent about 2 hours getting mine all lined up last summer. Trial end error...and patience.
Steve
My Photo Gallery
