Gas tanks
AustinTom
Gas tanks
Post by AustinTom »
I was cleanin up in the yard today and found an old Jeep CJ-5 gas tank. Not very big (the kind that is under the drivers seat) and decided to test to see if it would fit as a behind the axle tank in my parts bump (bare frame). It almost does. there's planty of room side to side, but the rear crossmember would have to be moved back about 2-1/2 inches is this feasable? Or should I try to find something that fits better?
69 F-100 lwb 240 Np435
95 F-150 lwb 4x4
http://s110.photobucket.com/albums/n85/ ... type=local
67mann
re: Gas tanks
Post by 67mann »
:? Are you adding a second tank or getting it out of the cab? Or is the one in the cab Bad? Reason I ask is I've got 3 in cab tanks. I switched to frame tank,but stole it out of a CS and it was a direct swap of parts. Almost any Fabrication is possible,but is it worth the time and trouble for the gain---just my :2cents:
foghorn
re: Gas tanks
Post by foghorn »
I would say that all you have to do is grind the heads off the rivets and move to where you want it and drill and bolt it in no problem.
Foggy 8)
VABowler
re: Gas tanks
Post by VABowler »
From what I've heard, the tank from a B2 will work. Was told it was a good candidate as it fits in the frame no problem. Just strap it in. :2cents:
1970 Ranger XLT
There's Only One Real Truck. And It's Made By Ford!
crazyhorse
Re: re: Gas tanks
Post by crazyhorse »
VABowler wrote:From what I've heard, the tank from a B2 will work. Was told it was a good candidate as it fits in the frame no problem. Just strap it in. :2cents:
ok , i gotta ask :? what is a
B2 ? thanks. :fr:
mljjones67
Post by mljjones67 »
Bronco two
flyboy2610
Re: re: Gas tanks
Post by flyboy2610 »
B2 ? thanks. :fr:
Kinda hard to imagine the tank from that fitting in your frame rails, though. :?
crazyhorse
Re: re: Gas tanks
B2 ? thanks. :fr:
what i thought. but........... who knows? :fr:
mljjones67
Nice pic!!!!
carcrafter22
Post by carcrafter22 »
Yeah you can move the crossmember to make it fit. I put a fuel tank from a 2003 ranger into my bump. I had to do a great deal of modification to one of the crossmembers t make it fit, I spent the better part of a day making it work. I guess it all depends if its worth it to you or not.
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
