Removing rear e-brake cables
Is there a special tool or technique to remove the rear emergency brake cables from the brake backing plate? I plan to replace mine with a good used set from another rearend, but don't know how to get the darned things off without breaking the little retaining tabs. I seem to recall someone mentioning a while back that it required a special tool for removal. Anyone know what it looks like and where to get one?
re: Removing rear e-brake cables
Well, I got the cables out, by sliding the box end of a 9/16" wrench over the cable to compress the tabs which allowed it them to slide out of the backing plate. I could also have used a hose clamp to compress those tabs, but the wrench was faster.
But now I've run into another dilemma that I'm hoping someone can help me with, and that's the routing of main emergency brake cable. Normally, the cable goes from the pedal assembly in the cab, down through the left front cab mount to a bracket on the frame, approximately under the driver's seat. From there, the cable goes straight to the middle of the rear frame crossmember, where it attaches to the two individual rear cables. However, because I'm now using the auxiliary tank, there isn't a straight shot from the frame bracket under the driver's seat on the frame back to the rear frame crossmember. Does anyone know if there's another setup used on trucks with the spare fuel tank? Somehow the main e-brake cable has to get around the tank to reach the rear crossmember, but with the tank in place, the main cable will be too short to go around (or over) the tank. Hmmmm..... :hmm:
In this pic, #1 is the bolt hole on the frame which holds the e-brake cable bracket. From there, normally it's a straight shot to the lever on the rear crossmember (#2). As you can see, this won't work. Any ideas?
Thank God I take lots of pictures! Here's one I found of the original bracket still installed, so you can get an idea of what it looks like.
4x4x4crewcab
Post by 4x4x4crewcab »
Keith
I will email you a scan of the parts illustration. The catalog shows a longer front cable #C7TZ.2853.C (80.05" LONG) on trucks with 25 gallon
floor mounted tank. It also lists a different number for the parking brake equalizer lever# C7TZ.2A605.A on trucks with 25 gallon floor mounted tanks. (you will see these numbers listed in the ill.) The longer front cable mounts to the front corner of the tank.
Hope this helps you I have trouble trying to post an image. Please post photo after you recieve it
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
4x4x4crewcab
Keith here are some phone numbers of dealers that show having stock available:
Dealer Name Phone Parts Searched For Quantity Discount
FREESE MOTORS INC
MONTICELLO, IA 319-465-3541
800-397-3541
C7TZ2A605A 1
KAMA OBSOLETE FORD PARTS
E BETHEL, MN 763-434-0123
C7TZ2A605A 1
BOWMAN SALES & SERVICE
BOWMAN, ND 701-523-3257
800-472-2218
C7TZ2A605A 1
ANTIQUE AUTO SUPPLY
ARLINGTON, TX 817-275-2381
C7TZ2853C ST
C7TZ2A605A ST
GREEN SALES
CINCINNATI, OH 513-731-3304
800-543-4959 C7TZ2853C 4
C7TZ2A605A 4
DALE KING OBSOLETE PARTS
LIBERTY, KY 606-787-5031
877-246-1111 C7TZ2853C ST
C7TZ2A605A ST
DENNIS CARPENTER FORD REPRODUC
CHARLOTTE, NC 704-786-8139
800-476-9653
C7TZ2A605A ST
DEALER AUTO PARTS
APACHE JUNCTION, AZ 480-288-9878
800-640-3321
C7TZ2A605A 2
BOB LYNCH FORD
GILROY, CA 408-847-1111
C7TZ2A605A 1
NOS ONLY
SAN JOSE, CA 408-227-2353
C7TZ2A605A ST
Mark
1999 Ford Windstar
4x4x4crewcab
Your original style cable shows 77.75" long. Not sure of the difference in the equalizer but does have a diff. number for the 25 gallon tank setup. Also the way the ill. looks the front bracket shown in your second photo
appears to not be used with this setup? :hmm:
Mark
1999 Ford Windstar
Mark: Thanks! I took the liberty of cleaning and touching up the scan...that's what I've been tinkering with for the past hour. Since it's too big to post inline, here's a link to the image: CLICK HERE
That definitely answers the question...my application will require an entirely different front cable. I'll go ahead and give the vendors you listed above a call to see if they have it and what it's going for. However, even if they don't have it, I know where there's another truck in a salvage yard with this tank setup, so I can just get it there.
...and you're right, it appears that the bracket I have pictured above in the second photo is only used on trucks with the in-cab tank. It won't be needed on my application because the cable hooks to the side of the fuel tank instead. However, according to the part numbers on this scan, the equalizer bar has the same part number for all applications (2A605), or am I reading it wrong? Where did you see that number with an "A" suffix?
muchtomydelight
Post by muchtomydelight »
I could use a new main cable if you have one to sell me- the spiral wire around the outside apparently got weak from my exhaust and split. Now instead of applying my brakes, it balloons the cable housing out...
4x4x4crewcab
Keith
The numbers listed in any illustration photo(s) are simply called a basic number. All of these numbers will generally (90% OF THE TIME) be the same for all cars and or trucks. 2853 is always a front e-brake cable, a 2A635 number is always a rear cable regardless of application or side. A 2780 is always a e-brake pedal assy etc...........
A text catalog for model application must be referenced for the complete part number.. and after checking the text catalog application and description for this setup on this year and style truck a different part number was issued for the 2A605 part . What the differences are it don't say but in most cases if its a different # it won't interchange. A true Master set of parts catalogs will have 2 books in the set
1) Illustrations catalog (photos with basic numbers only)
2) Text catalog usually a much larger book containing full part numbers
and general descriptions of parts only (no photos in this book)
The second book is the MEAT the first book is just the POTATOES
Mark
1999 Ford Windstar
4x4x4crewcab
Keith
P.S. your clean-up job of the scan looks great. I guess the photo
on the back of the page blead through in the scan. Sorry it was the best I could do with the equiptment and time I have.
Mark
1999 Ford Windstar
Re: re: Removing rear e-brake cables
Mark: Sorry...I guess I knew that, but it wasn't clicking upstairs....heh...thanks!
muchtomydelight wrote:I could use a new main cable if you have one to sell me...
I should have a couple of those floating around the shop that I was saving for spares....but it ain't lookin' like I'm gonna need 'em! It might be a few days before I can get back to the shop though, but when I do I'll grab ya one. I'll e-mail you when I get it.
jck_in_nc
Post by jck_in_nc »
There seems to be a conspiracy against making it easy to figure out which cables are right for the 131" 1967 f-100 and where to get them. I need the two that go into the brake backing plates. I don't have one of those fancy onder-bed tanks, just the standard in-cab.
Thanks,
jck
Frame-off Restore
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
binder56jd
Post by binder56jd »
Keith-Thexton Mfg. Co. part #450 $15.53 www.thextontools.com ps post a lesson on how to do links i've never learned- thanks JD
now serving #235
willowbilly3
Post by willowbilly3 »
Mark, you are amazing. What would we do without you?
I hauled the rear end out of the 72 to a guy last week and he almost kissed me because it had good brake cables and I hadn't torched them off.
jck_in_nc wrote:There seems to be a conspiracy against making it easy to figure out which cables are right for the 131" 1967 f-100 and where to get them. I need the two that go into the brake backing plates. I don't have one of those fancy onder-bed tanks, just the standard in-cab.
Thanks,
jck
Ask, and ye shall receive:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33568
I just checked, and these are the correct parts for your application.
