70-72 parking light housing bolts
has anyone ever attempted to replace the bolts on the bottom of the 70-72 parking light housings? if so what kind of bolts did you use and how did the lights fit between the lower valance and the grill?
- peanutman
Ford man im gonna have to replace my valance on my 70. Bent right in middle some how. So i will be removing parking light housings. Looked at the them other day while working on that ongoing elec problem. Looked like some type of flat head bolt going thru them.
Also looks like you may have to remove bumper and valance to get them off or maybe grill not much room in there to work.
Will be a while before i get to that but will let you know if you have not figured it out by then.
http://s533.photobucket.com/albums/ee33 ... e_Johnson/
1970 302,ps, ac, 3 speed o.d.
i have these of already. but the bolts broke off. they are spot welded to the bottom of the housing. i know i can grind off whats left i was just wondering the best way to replace the broke off bolts. to remove them i just had to take the bolts out and kind of wiggle them and they came out.
it would be easier if the grill was off though.
- 1971fordcustom
Mine busted off to!!!!!! Thank god I had 2 more off a parts truck!! Jb weld maybe!!!fordman wrote:i have these of already. but the bolts broke off. they are spot welded to the bottom of the housing. i know i can grind off whats left i was just wondering the best way to replace the broke off bolts. to remove them i just had to take the bolts out and kind of wiggle them and they came out.
http://s205.photobucket.com/albums/bb31 ... d%20F-100/
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1960 Ford F-750 FireTruck
1960 Gmc 6000 FireTruck
1962 IH R-185 Firetruck
1959 Ford Custom 300
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
- peanutman
I will attempt to straighten it but it's got a ugly crease right in the middle. Not sure how somthing got in ther without getting the grill.
