Crew cab guys help!
James72
Crew cab guys help!
Post by James72 »
I will soon be starting body work on my '72 crew and need to know what you guys are doing about rear doors (I know they are the same as fronts just cut off) and the pillar between the doors. All these panels on my truck are rusted badly I would like to replace the doors with new ones but can't find any, and as for the pillar I was thinking about cutting up a new door skin for that area. I have looked pretty hard for new crew panels but can't find any. Any help would be great. Thanks
i have some extra doors. both sides. i was going to probably junk. i could cut the skins off of them to use as repair pieces. they are decent enough for that.
James72
re: Crew cab guys help!
Post by James72 »
my inner part is rusted aswell I could really use the whole doors, I'm sure anything is better then what I've got.
71Ford100
Post by 71Ford100 »
Good luck on those. Got any pics of the rust?
Lance Peters
James72
Post by James72 »
Here ya go[/img]
more to come, trying to figure out new camera
kopcicle
Post by kopcicle »
http://www.toolking.com/astropneumatic_ap600st8.aspx
http://shop.1asecure.com/prod.cfm?ProdI ... &StID=4966
http://www.sjdiscounttools.com/sem69508.html
do you have or have access to oxy-acetyl ?
can you braze uphill with out distorting the metal ?
do you have common body hammers and dollies ?
do you have WAY to much time on your hands and want it right ?
please note that starting with the best piece of metal available for the money will significantly ease the project along and cut the time needed for a good job way down .
There are two major pressure changes in a four stroke internal combustion engine , when you light the fire and when the rods exit the block.
James72
Post by James72 »
Here's some more, also I can cut and weld well (not a pro at all) The last time (and first) I tried brazing was in school so I will have to find someone who can.
kopcicle
Post by kopcicle »
Brazing uphill just takes more patience and fine heat control . A tip ...
heat ahead of (above) where you want to deposit rod (exactly backwards of gas welding ). Use bare rod and a can of flux (if you can find it !!) have several rod sizes on hand 3/32 , 1/8 , 5/32" , applying rod to a heated area not only deposits material but removes heat . Lastly , CLEAN CLEAN CLEAN where ever you want to braze .
Setup a practice piece about the same thickness and see how it goes . PM any time
71Ford100
Post by 71Ford100 »
Somewhere on ebay there is a guy that is selling a piece of trim for our bodystyle and their is a crew in the pic that has for sale written in the window. I've e-mailed him twice about buying it and I haven't recieved a response yet. I think your best bet would be to get some regular doors and cut out what is rusted out on the back doors and patch it in.
Lance Peters
Teacherman
Post by Teacherman »
Let us know how that turns out. My dad cut out spots in the pillars and installed speakers there. I'd eventually like to pull those out, but I didn't know how much a pain in the butt it would be to fill in the holes. Keep in mind I teach writing for a living, so doing it myself is kind of out of the question.
1972 F250 Crew Cab
Family heirloom
Photo gallery: http://www.fordification.com/galleries/ ... ?cat=10482
71Ford100
Post by 71Ford100 »
I have holes cut in mine as well but I plan on putting new speakers in towards the end of my project. You should keep your dads handywork and besides more speakers there are the louder you can go.
Lance Peters
basketcase0302
Post by basketcase0302 »
I contacted the owner about three weeks ago, (the truck is in Florida).
He wants $3500 for the whole truck! :rant:
4x4x4crewcab
Post by 4x4x4crewcab »
James72 back in the project update pages I had many posts and pictures of my rear door repairs etc.. cut fronts for inner and outer rear door patch panels, split apart, cut down, welded on. It should still be on there but I'm sure its a few pages back. It sounds exactly like what your describing. They did make nice replacement panels and even had all the correct body lines etc...
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
James72
Re: re: Crew cab guys help!
Post by James72 »
[quote="4x4x4crewcab"]James72 back in the project update pages I had many posts and pictures of my rear door repairs etc.. cut fronts for inner and outer rear door patch panels, split apart, cut down, welded on. It should still be on there but I'm sure its a few pages back.
I found the page, read the praises, but the pictures are unavailable :( .
I thought of going that route but hoped there was pre-cut panels.
4x4x4crewcab
Sorry I was unaware the pictures were not available. Here are a couple that may be viewable
http://rides.webshots.com/photo/1215962 ... 2027MSxevb
and
http://rides.webshots.com/photo/1227592 ... 2027MWEZTB
Mark
1999 Ford Windstar
