Cab Mounts
- ford4x4fun
Cab Mounts
I had to cut the cab mounts off of the frame that I am putting a new body on, the other ones are good, but I can't figure out how to get them off, is there a trick for this or do I just have to design new ones???
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
US ARMY Retired
re: Cab Mounts
If you're talking about the frame mounts for the front of the cab, those are riveted on. Just grind the heads off and pound out the rivets, and then bolt them onto your other frame.
- ford4x4fun
re: Cab Mounts
OK, we need more clear info. Are you referring to the steel mounts or the rubber bushings? And are you referring to the front or the rear of the cab?
- ford4x4fun
There are 6 cab mounts for the cab. All 6 have a rubber bushing betwean the cab and the frame, and a bushing under the frame. Holding those bushings in place there is a piece of metal that holds them there that the actual bolts run through. I had to cut those off of the new frame, because they where rusted real bad. I can't figure out how to get them off of the old frame.
http://i184.photobucket.com/albums/x298 ... CN0443.jpg
In this picture you can see where the front clip hooks up and the front cab mounts. Those are the things I can't figure out. Thanks for any and all help.
US ARMY Retired
US ARMY Retired
- ford4x4fun
re: Cab Mounts
They'll pop apart as long as they're not rusted together...and 90% of the time they are, meaning you'll have to cut them off and order replacements from a vendor.
