Cab Mounts
slamons
Cab Mounts
Post by slamons »
Please tell me an easy way to remove the rubber / metal mounts that are bolted thru the frame then into the cab. I have the cab off and everything off of the frame to refinish but I cannot get these mounts off of the frame, getting ready to start cutting.......
1971fordcustom
Re: Cab Mounts
Post by 1971fordcustom »
slamons wrote:Please tell me an easy way to remove the rubber / metal mounts that are bolted thru the frame then into the cab. I have the cab off and everything off of the frame to refinish but I cannot get these mounts off of the frame, getting ready to start cutting.......
Well Cut away :wink: . try a :air chisel to see what that does
http://s205.photobucket.com/albums/bb31 ... d%20F-100/
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1960 Ford F-750 FireTruck
1960 Gmc 6000 FireTruck
1962 IH R-185 Firetruck
1959 Ford Custom 300
1940 Ford Truck
flyboy2610
Post by flyboy2610 »
Are you talking about the rear mounts? If I recall correctly, these have a 'twist lock' arrangement that is next to impossible to remove when rusted together. You'll have to cut them off somehow.
Sorry.
for the front mounts i use a sawzall and cut the bolts right through the rubber at the same time. i just cut from the top of the cab mount. the rear mounts i take a large punch and hit the inside center of them and they pop apart.
slamons
re: Cab Mounts
Post by slamons »
Thanks for all the replys, I will just cut them off, I have tried to use a punch and every other thing I could thank of.....
