Surface Rust?
Surface Rust?
Hey Guys........ I have some surface rust in the bed of my '69....... Its not a lot now but as you guys know, it will be later. What do you guys recommend is the best and easiest way to solve the rust problems?
- 69twotone
re: Surface Rust?
Nice truck stangman.
Sandpaper and a sanding block or a wire wheel. Then cover it with primer or paint.
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
- MAK
re: Surface Rust?
I was dealing with surface rust a while back and couldn't get it all off with just abrasives. Finally found a solution using Naval Jelly in combination with abrasives and it worked great. See my post:
http://fordification.com/forum/viewtopi ... rface+rust
- flyboy2610
re: Surface Rust?
Bondo makes a product called "One Step." It's a spray on product that stops rust and chemically converts it. I have used it many times and really like it. Follow the directions, and then primer and paint over it.
- marz68
Re: re: Surface Rust?
He flyboy how many cans of ONE STEP do you think it will take to cover my entire truck?flyboy2610 wrote:Bondo makes a product called "One Step." It's a spray on product that stops rust and chemically converts it. I have used it many times and really like it. Follow the directions, and then primer and paint over it.
