disc brake lug swap question
tybob81
Post by tybob81 »
What year disc brake rotors can I use to get the 5x4.5 bolt pattern. It was on here awhile back and I can't remember if it was a fairlane or mustang and what year. I know if you use a 73 and up torino you can have the 5x5. The rims I want are not offered in the big ford bolt pattern and I have a set of adapters but they cause them to stick out a wee bit to far.
fmartin_gila1
re: disc brake lug swap question
Post by fmartin_gila1 »
Check out the later F100 pickups, after Ford came out with the F150. IIRC the last of the F100s had the 15 inch with the small pattern. Could be wrong but worth checking.
Fred
MadMaxetc
Post by MadMaxetc »
There are not any rotors that I am aware of that have 5x4.5 that will fit your spindle.
Dan
FORD Girl
Photobucket Pictures
maybe granada and zepher?
tybob81
Post by tybob81 »
Keith would know for sure.
willowbilly3
Post by willowbilly3 »
I an going to guess the 70s torino. They pretty much used the same caliper and pad system. Go to the junkyard and pull on, measure the spindle length. As long as that's close you can get the bearings with the id you need.
