Receiver hitch
greenbank
Receiver hitch
Post by greenbank »
Anyone bought the receiver hitch LMC sells, and it it truly a "bolt on" device? I have a bumper hitch but would prefer to haul cars on my flatbed trailer using a receiver.
1968 F250 Ranger Camper Special
-- 360, AT, PS, PB, disks
-- See Goldie
heep70
re: Receiver hitch
Post by heep70 »
Mine isn't from LMC, but it is truely a bolt on. Just clamped it to the frame and drilled the holes needed. I also welded .25" plate around the tube and bolted that to the bottom of the bumper. Easy money!
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
mrsnicks
Post by mrsnicks »
Umm... Heep... if you have to drill holes, it's not a "bolt on". True bolt on means not modification to install.
Was the welding required, or just you strengthening it?
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
heep70
re: Receiver hitch
Post by heep70 »
Well OK, my error. I am used to a little labor when it comes to fitting things to this old rig :doh: . Then I guess there is no such thing as a bolt on hitch for a bump that I have seen. No welding involved as far as mounting it to the pick up frame.
Greg
greenbank
Post by greenbank »
Yeah, I was wondering about the drilling. Not that big a deal, but "true bolt on" would sure be convenient.
-- See Goldie
flyboy2610
re: Receiver hitch
Post by flyboy2610 »
This is the DrawTite receiver hitch I installed on my '69 F250CS. The side brackets have three holes in them. The center hole lines up with a hole in the frame, then you have to drill two holes per side in the frame. It's not hard to do, just don't try to get the final hole size at first. Start small and work your way up, increasing the hole size in steps.
It was not hard at all to install. I can't find the paper that has the model number on it, and it's dark outside right now. It's made for '67-72 Ford F series trucks, and is the hitch for a deep drop bumper.
Even though I don't consider this bumper 'deep drop'. :lol:
cghstrojan08
re: Receiver hitch
Post by cghstrojan08 »
I like that new bumper.
ROBERT
Member #1076
1968 F100 SWB 360
flyboy2610
Re: re: Receiver hitch
cghstrojan08 wrote:I like that new bumper.
Thanks! It's the LMC Starlite bumper, with the polymer step pad.
greenbank
Post by greenbank »
Yeah, that's what I want. I have the "same" bumper, except mine is plain painted without lights and such.
Meant to add: did you buy the receiver from LMC?
-- See Goldie
flyboy2610
re: Receiver hitch
No, I ordered the Hitch from Draw-Tite.
http://www.drawtite-hitches.com/product ... iver,41504
I can't find the instruction sheet, but that model number sounds right. It's for a '69 F250CS with a deep drop bumper.
I like it.
greenbank
Post by greenbank »
Thanks, I ordered it from Amazon. Their price was a bit mroe than Draw-Tite but instead of $50 shipping it was free shipping, so it came out less overall. Thanks!
-- See Goldie
flyboy2610
re: Receiver hitch
You're welcome!
This is from a post I made in September when I installed it:
So, now the new bumper is on. Time for the hitch.
I had purchased a Drawtite hitch for the truck, and since I had the new bumper on, it was time for the hitch. It was easy to install. There is a 1/2" hole factory drilled in the bottom frame rail. The hitch attaches with 1/2" bolts. So i just used that hole and installed one bolt one each rail, then hung the side brackets for the hitch. I snugged the bolts up a bit, then measured between the front of the brackets and adjusted the positioning of them until it was 33", which is the distance from outside to outside of the bolt plates on the receiver assembly. Then I marked the spot for the holes and drilled 2 1/2" holes in each frame rail. Then I installed the receiver assembly, and made any final adjustments to get it centered, then tightened down the bolts.
Good luck with it!
:thup:
