Floor / support brkt
slamons
Post by slamons »
Need Help....My truck is nearly rust free with the exception of the middle floor support under the drivers side. This is not the front or rear cab mount but the out side 6 inches of the support brkt itself. In all the patch kits they only list the rear cab support....Can any one help and tell me if they make what I need and where I can find it Or am I being completly ingnorat and not seeing what I need....Please Help.....
MAK
re: Floor / support brkt
Post by MAK »
I purchased some cab supports from NPD a while back but was unhappy with the quality.
http://fordification.com/forum/viewtopic.php?t=24833
Still not sure if I'm going to use them and just weld over top of the existing ones or try to find some that are the correct size and better quality. Let me know if you find some from another vendor that fit well and are the correct thickness. Dennis Carpenter is known for usually having good quality parts and uses orig Ford tooling for a lot of their parts. I'm happy with the floor panels and cab corners I got from them.
